| Re: Sticking Clutch Because you mention weights attached to the pressure plate it leads me to believe you have a ford unit upgraded by centerforce or a centerforce clutch both of which would have several small weights as you said.
I have unstuck fricton disks by getting a couple of friends to rock the car to and fro while you or your wife holds the clutch in (disingauged) with the car in gear. You can do this alone if necessary by depressing the clutch peddle with a 2X4 braced against the seat and rocking the car yourself. Of course I mean the engine is OFF during this proceedure. In your case, with a renault bellhousing, you can get to the friction disk to pry it loose and that sounds like the first thing to try. I would us a flat blade puddy knife instead of a screwdriver and be careful not to gouge the friction material.
Simply starting the car up and kinda making sure everything works,including the clutch, every couple of weeks is a good idea for many reasons. Turn on lights, fans, AC, turn signals, Bring up to temp. etc. Allow engine to consume fuel in carb. before turning off engine. I turn off my pumps and wait for the engine to use up the fuel in the fuel bowls. Prevents the fuel from turning into that varnish looking stuff in the carb. needle and seats, metering block etc.
Lastly fill out your information stuff completely. Here is a case of me not knowing if you are in Asia or some other place named Singapore. The winters might be quite different and so is the rust problem you have on your flywheel, leads me to believe Asia. It is also helpful for others to recomend local sorces for you if we know where you are. This is the most important thing for you other owners of GT40s using this site as a resorce. Real Name, Full Location, Just trying to help. |
