Old 05-17-04, 08:13 AM   #1 (permalink)
flatchat's Avatar
flatchat
7 Tenths
Head Gasket Quiz
Am interested in what "racers" are using to keep the fire from the water jacket(gaskets??)in small block fords? assuming all tuning is within normal safety parrameters.
10.5:1 Comp/ratio,4-7000rpm for 15 to 60 minutes.
TX
Chris [img]/ubbthreads/images/graemlins/cool.gif[/img]
flatchat is offline
Old 05-17-04, 02:00 PM   #2 (permalink)
Kalun_D's Avatar
Kalun_D
5 Tenths
GT40: Scratch build
Rep Power: 11 Kalun_D will become famous soon enough
Re: Head Gasket Quiz
Most aluminum head manufactures specify a specific gasket that needs to be used with their product.
AFR's 165cc street head uses a Fel Pro #1011-2 head gasket on a 1983-93 302.
Kalun_D is offline
Old 05-17-04, 06:28 PM   #3 (permalink)
Lee
Lee's Avatar
Lee
5 Tenths
GT40: GT40 Australia
Rep Power: 12 Lee is on a distinguished road
These are the gaskets I am currently intending using. I understand they can be re-used. The top of the block is machined for O rings. Any helpful comments or suggestions welcome.
Lee is offline
Old 05-17-04, 06:30 PM   #4 (permalink)
Lee
Lee's Avatar
Lee
5 Tenths
Picture showing part number. They are solid copper. These are 93 thou thick.
Lee is offline
Old 05-17-04, 06:35 PM   #5 (permalink)
Lee
Lee's Avatar
Lee
5 Tenths
Here are the O Rings.
Chris
What happened to your old gaskets. Was it a big problem?
Lee is offline
Old 05-20-04, 06:59 AM   #6 (permalink)
flatchat's Avatar
flatchat
7 Tenths
Thx Lee ,they're thick gaskets Huh,you'll need pop up pistons or a 48cc combustion chamber to get some compression
I've had good results with Felpro 1011's-- but we didn't use them in this instance .could be a lean out/to much spark advance at high RPM resulting in a detonation problem?? still investigating.
Jinxed [img]/ubbthreads/images/graemlins/cool.gif[/img]
flatchat is offline
