Old 06-07-04, 01:04 PM   #1 (permalink)
3 Tenths
GT40: USA
Rep Power: 9 JOSEPH is on a distinguished road
016 FAILURE ???
Has anyone had a Getrag 016 fail because of to much HP or Torque? And how much HP did you have when it did fail? Joe [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
JOSEPH is offline
Old 06-07-04, 02:27 PM   #2 (permalink)
Mark Worthington's Avatar
Mark Worthington
GT40: Massachusetts
Re: 016 FAILURE ???
Hershal's is the only one I know of that failed. He did it while drag racing at Run & Gun last year. Transaxles don't fail from HP, they fail from torque. I don't know too much about Hershal's engine, but I would guestimate that it makes somewhere around 350 lb-ft of torque at the rear wheels. The failure mode of his transaxle was the cast-iron gearbox housing, which I believed cracked at the mainshaft bearing.
Why do you ask, Joseph? Is your 016 not healthy?
Mark Worthington is offline
Old 06-07-04, 07:07 PM   #3 (permalink)
patbarry's Avatar
Gold Supporter
GT40: Houston, Texas
Re: 016 FAILURE ???
Isn't the 016 box aluminum?
patbarry is offline
Old 06-07-04, 10:50 PM   #4 (permalink)
Mark Worthington
GT40: Massachusetts
Re: 016 FAILURE ???
There are three main exterior pieces on the 2WD 016. The transaxle case with integral bellhousing is cast aluminum. The middle piece is the End Shield and it's made of cast iron (possibly sintered pot metal). The rear piece is called the Gearbox Cover and it is cast aluminum. The Audi 012 box is all aluminum. The 01E box also uses a cast iron End Shield.
Old 06-08-04, 12:46 AM   #5 (permalink)
3 Tenths
GT40: USA
Re: 016 FAILURE ???
Hi Mark, Actually my 016 is very healthy at the moment, but my 302 is getting stronger. [img]/ubbthreads/images/graemlins/grin.gif[/img]
JOSEPH is offline
Old 06-08-04, 12:51 AM   #6 (permalink)
3 Tenths
GT40: USA
Re: 016 FAILURE ???
Oh Mark, " J B WELD " claims that it will fix a cracked block. What do you think? Ha Ha.
JOSEPH is offline
Old 06-08-04, 01:46 AM   #7 (permalink)
Hershal Byrd
GT40: RF
Re: 016 FAILURE ???
Ok guys,
here's the scoop on what happened to my Gear box. I have an 016 3U box. I believe that it has in ecess of 100,000 miles on it. I put it in without any work being done to it. While at Run & Gun on the drag race portion of the compitition I pulled a hole shot at 6,000RPM and when I went to back up to the starting line it would not go into reverse. I then put it in second and drove to the pits. I put it on the trailer and brought it home. My trans guy took it apart and discovered what happened. The mid section of the trans that houses the rear main shaft bearing failed.
It is made of cast iron and it had alot of pourosity in the area around the main bearing collar. This piece cracked off and fell down into the reverse gear which prevented me from going into reverse. My trans guy said that I pushed in the clutch at the right time because there was no damage caused to the other gears. He rebuilt the tranaxle for $300.00 dollars including parts. It really feels nice and tight now as opposed to the way it used to be.
My engine is a 306CI with 425BHP at 365 FT LBS of torque.
I firmly believe that this is a solid trans and it works well as long as you stay within the limits of it's capability. Remember that this trans was in a car that weighed around 4,000 lbs. and we use it in a car that weighs less than 2500 lbs. This is why we can use it because the torque is better as long as you don't use monster wide tires. Still, the fact remains that this is a roadrace car and not a drag car.
For the fact that this trans is extremely cheap and readily eccessible I will continue to use it. If I do
change to something else it will be the 01E 6 speed. This is a trans that Audi uses in the A8 and the RS6. which is rated over 380HP. For $6,000 bucks that is a good trans to have. Roaring Forties is the only GT40 manufacturer that offers this option at this time. The Blue GT40 in the video clip that was on another thread has this trans and it is awsome according to the owner.
I hope this year at Run and Gun I see other manufacturers represented. Rick Merz was there last year with his GTD. We had great time and I hope others will join in on the fun with their GT40. I know of no other venue that gives us the chance to get together and have a fun compitition with each other. I'll be there and I hope there will be many others bringing their GT40's.
I'm lookin' to kick some but this year!!! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
Hershal Byrd is offline
Old 06-08-04, 10:53 AM   #8 (permalink)
3 Tenths
GT40: USA
Re: 016 FAILURE ???
Hi Hershal, Is that HP and LBS. FT of torque at the rear wheels? Joe [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
JOSEPH is offline
