Old 07-21-04, 12:39 PM   #1 (permalink)
mike_starling
Location: 59 years old. Went to college in Florida during the Ford-Ferrari wars. Was a pit steward for the D
GT40: WV
Rep Power: 7 mike_starling has a spectacular aura about
bolt pattern dimensions for G50/52??
Guys,
I note the nice drawings of mounts for the G50 transaxle.
Can anyone send me the dimensions of the bolt pattern for the G50/52 transaxle that would be used to connect to a mount.
Turns out I did not get any mount with my chassis and I'm going to have to make one. A good set of dimensions would obviously be very helpful!
Thanks VERY much!
mike_starling is offline
Old 07-22-04, 04:38 AM   #2 (permalink)
Kalun_D's Avatar
Kalun_D
5 Tenths
GT40: Scratch build
Rep Power: 11 Kalun_D will become famous soon enough
Re: bolt pattern dimensions for G50/52??
This adapter is for a G50, don't know if the G50/52 has the same bolt pattern.
KEP sells one for about 200.00 I just wanted to make my own so I could integrate trans/engine mounts.
The mounts aren't drawn in this 2D .dwg, they are on the bottom corners and are urethane just like the rear trans mount you mentioned.
This adapter is made from 5/8" 2024 T4(?) plate. I bought a piece from KEP when I bought the flywheel/clutch package.
The G50 locates with a lip on the inside edge of the adapter, the 302 locates with 2 dowel pins. The lip is formed by machining a 1/8 x 2" wide band that the trans bolts to and leaving the 5/8 thickness to form the lip.
first you cut out the large center hole that the flywheel fits in and drill the trans holes and machine the lowered band area.
Then you clamp the adapter to your block with the crankshaft bolted in.
The most important and most tedious step is to perfectly center the large center hole to the crank, + or -.005"(?). Then you center punch the two dowel pin hole locations on the adapter with a transfer punch that you put through the back of the block dowel pin holes. The transfer punch has to fit very tight in the dowel pin holes otherwise it won't be accurate.
Then drill the dowel pin holes on the adapter with an accurate drill press or mill.
It's been about 2 years since I built mine, I may have transfer punched the trans holes also. Without a 24" caliper it's the most accurate way. The hole locations in the drawing aren't that accurate because I didn't have the proper measuring tools. It's just a general plan and you mark the holes accurately using the transfer punch method.
just realized I misread your post, oh well maybe someone needs plans for an adapter also [img]/ubbthreads/images/graemlins/grin.gif[/img]
Kalun_D is online now
Old 07-22-04, 06:00 AM   #3 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
Mike,
I've gotten together a dozen or so photos for you. I just have to scan them so that I can email them to you. They inlude shots of the mount.
I was going to send you an email last night to let you know this, but was sooo tired when I went to bed around 1AM that I forgot.
Sorry,
Lynn
llarsen is offline
Old 07-22-04, 09:15 AM   #4 (permalink)
mike_starling
GT40: WV
Kalun,
Sorry, I did not make myself clear. Wanted the dimensions of the bolt pattern of the transmission joint line where the rear support for the transaxle would be fitted. Can and will make my own adapter, but it's easier if I have a good set of dimensions to check mine.
I have the adapter plate from KEP.
mike
Old 07-22-04, 12:11 PM   #5 (permalink)
daveharris
3 Tenths
GT40: Northern Ca,
Rep Power: 10 daveharris is on a distinguished road
If someone does not have a drawing that they can dimension, I can remove mine from my trans and trace a template for you (trans in out of the car right now). Mount is for a DRB chassis, but the bolt pattern is what your after.
cheers
daveharris is offline
Old 07-22-04, 12:22 PM   #6 (permalink)
mike_starling
GT40: WV
Dave,
Sure would appreciate it. Let's wait a couple of days and see what shows up on this thread ... if that's reasonable.
Thank you very much!
Old 07-22-04, 04:31 PM   #7 (permalink)
daveharris
3 Tenths
GT40: Northern Ca,
No problem Mike - If you send me an e-mail to my home this weekend saying you need the pattern I'll trace it off for you.
