Old 11-20-04, 12:33 PM   #1 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Engine Mounts
Can anyone tell me the part number of the engien mount that the GTD uses? I bought some, but they appear to be wrong. Thanks
Brett
brettmcc is offline
Old 11-21-04, 04:01 AM   #2 (permalink)
Fred/GT40
8 Tenths
Belgium
GT40: GTD40
Rep Power: 15 Fred/GT40 is a glorious beacon of light
Re: Engine Mounts
I also understood you can put stronger type of engine mounts.
Anyone more info on this?
Fred/GT40 is offline
Old 11-21-04, 09:00 AM   #3 (permalink)
wealdenengineer
Rep Power: 0 wealdenengineer has a little shameless behaviour in the past
Re: Engine Mounts
Brett, I will swap the ones you have for a neww set of GTD type mounts, Frank
wealdenengineer is offline
Old 11-21-04, 01:36 PM   #4 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Engine Mounts
Frank,
I have some \Lockwood mounts, which apparently come out at the wrong angle to match up to Roy's mounts. Can you post/send a picture?
Brett
brettmcc is offline
Old 11-21-04, 02:27 PM   #5 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Engine Mounts
Picture of the Mount
brettmcc is offline
Old 11-21-04, 02:28 PM   #6 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Engine Mounts
and this is what is happening
brettmcc is offline
Old 11-21-04, 02:46 PM   #7 (permalink)
wealdenengineer
Re: Engine Mounts
Brett, call me ! Frank
Old 11-21-04, 03:10 PM   #8 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
Re: Engine Mounts
Brett,
I bought a set of these from NAPA and they fit like those pictured. Come to find out they were made in China. The other source that NAPA has for these parts is in India. I made sure that the next set was sourced from India and they fit much better. I don't know if your vendor has the same sources - it wouldn't surprise me if they did - but then you may be running into the same thing.
Lynn
llarsen is offline
Old 11-21-04, 04:44 PM   #9 (permalink)
Ron Earp's Avatar
Site Administrator
Re: Engine Mounts
What happens when you flip them around? I assume it gets worse?
Ron Earp is offline
Old 11-21-04, 05:06 PM   #10 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Engine Mounts
Yep,
Just to explain, the other mount is already connected. Apparently I need a mount, which is closer/more vertical. Frank Catt has given me the Road craft part No: RUKMNT04. Anyone know what that translates to in Ford speak?
Brett
PS anyone want some Lockwwod Performance Mounts (that won't fit a GT)
brettmcc is offline
