Old 11-23-04, 12:12 PM   #1 (permalink)
porsche93's Avatar
porsche93
2 Tenths
GT40: RF Chassie 90
Rep Power: 8 porsche93 is on a distinguished road
Oil pump drive
On the SBF when going without a distributor what is being used to drive the oil pump? I have found that you can use a Cam Position Shaft from an Explorer but was hoping that I could use something that did not include my buying a sensor.
Peter
porsche93 is offline
Old 11-23-04, 01:00 PM   #2 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
Re: Oil pump drive
Peter,
Some guys have used an old distributor that is cut off and capped. Seems like I recall a thread on this. Try some searches on distributorless igntion terms to find the thread where this was talked about.
Seems that the Explorer part was mentioned, so maybe you've already found the thread I am thinking about.
Lynn
llarsen is offline
Old 11-23-04, 01:06 PM   #3 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
Re: Oil pump drive
I presume that you are running a wasted spark setup? otherwise the phase and sync available from the aftermarket (Explorer) sensor would be useful.
We used an old distributor cut down but as we are now dry-sump - it only provides phase signal.
Anyone got an old distibutor (bits missing etc) they don't need anymore???
p thompson is offline
Old 11-23-04, 01:18 PM   #4 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Oil pump drive
One sitting in my shed at the moment [img]/ubbthreads/images/graemlins/grin.gif[/img]
Brett
brettmcc is offline
Old 11-23-04, 05:17 PM   #5 (permalink)
porsche93's Avatar
porsche93
2 Tenths
GT40: RF Chassie 90
Re: Oil pump drive
Lynn,
No, I did not find that information here, I found it on the net when researching this question.
I should explain what is going on. I have been putting the parts togeather for my motor and purchased the injection and Tech3r computer from Wayne. long decision process but it boiled down to his having had a 40 and being very easy to work with, along wth total price.
Anyway I had not given much thought to how I was going to run the system other than using the Crank Trigger. After seeing the replys to my question and reading more in the Electromotive manual I am leaning towards going full sequential on my injection. The Tec3r can handle both phased or sequential with the latter requireing a Cam Position Sensor and the phased using only the Crank Trigger. My question now is what is the opinion between the two setups, and does anyone know if the Explorer Cam Sensor and pump drive unit would be compatable with the Tec3r.
Peter
Old 11-24-04, 12:33 AM   #6 (permalink)
RTIMTE's Avatar
RTIMTE
2 Tenths
GT40: Plano, TX USA (Dallas)
Rep Power: 9 RTIMTE is a glorious beacon of light
Re: Oil pump drive
Peter,
MSD sells a plug/Sync distributor for the 302 or 351. Part 8522 for the 302 and 8506 for the 351W. They sell for about $140.00 US.
http://www.msdignition.com/2003/page_15.htm
RTIMTE is offline
Old 11-24-04, 09:37 PM   #7 (permalink)
DaveWharran's Avatar
2 Tenths
GT40: Clearville, PA
Rep Power: 10 DaveWharran is on a distinguished road
Re: Oil pump drive
Peter,
May or may not be any help, but I gutted the stock dist. on the Cleveland leaving only the shaft and top bearing, cut down the housing, and made an O ringed cap for what remained. All it does is drive the oil pump...plus the cap is personalized with the wifes name as well as mine. That always helps!!
I'm running wasted spark on a Haltech with triggering from 4 magnets set into the flywheel. They serve as both trigger and sync signals to a Hall switch. Thus, I needed no signals from the dist. at all.
Sorry so dirty! Body work is dirty, dusty business......
Glad that was a year ago.
DaveWharran is offline
Old 11-26-04, 08:47 AM   #8 (permalink)
porsche93's Avatar
porsche93
2 Tenths
GT40: RF Chassie 90
Re: Oil pump drive
Richard,
Thanks for the information on the MSD Plug/Sync. After reviewing the product and confirming with Electromotive that the ECU was compatable with the Hall Effect signal I ordered that unit.
I was able to find it for US118.00, once again tanks to all of you for your input.
Peter
Old 11-27-04, 04:12 AM   #9 (permalink)
Kalun_D's Avatar
Kalun_D
5 Tenths
GT40: Scratch build
Rep Power: 11 Kalun_D will become famous soon enough
Re: Oil pump drive
Make sure your cam is compatible with the iron drive gear on this piece. I know some of the roller cams need a hardened steel gear and won't work with the iron gear.
Kalun_D is offline
Old 11-28-04, 10:29 AM   #10 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
Re: Oil pump drive
Peter,
Good to hear from you and see you are making progress. How 'bout some recent pics in the Builder's Forum. The motor looked really nice, but it sounds like you've added a few bits since then.
Thought I was going to get down to So. Fla next week, but it got cancelled :-( Thanks again for having me over and the dinner! Next time dinner is on me. :-)
Lynn
llarsen is offline
