engine mounts
i'm scratching my head i have a pair of mustang engine mountings they seem to be identical not handed each mounting has one of the bolt holes mountings longer so i would expect the mountings to be handed if i fit them to my engine one mounting sits further forward than the other i think i must have either two lefts or two rights has any body got the correct part numbers for the mountings and does the longer bolt mounting go forward or to the rear
THANKS MIKE
i will take a carefull look at the mounting points to check which way round the mounts fit came to put them on last night and thought oh f**k these are wrong thanks for your help
chris
Welcome Chris...they pretty much can only be installed
one way....as I recall if you try to install them backwards
the mount hits the side of the block.
MikeD
Chris, I had a 2001 block 302 in my GT and all was good with the mounts. When I changes to a 71 302 block, all of a sudden the mounts would not line up properly /ubbthreads/images/graemlins/crazy.gif
I know it makes no sense at all. So I end up cutting about 1/4" from the Driver side mounts (For you brits, it is the passenger side!!) to make it fit.
