Old 09-14-05, 05:23 AM   #1 (permalink)
GT40: United Kingdom
Rep Power: 4 Cobra John is on a distinguished road
Radiator bleed valve
On the top of my standard GTD radiator I have two holes that are currently fitted with blanking plugs.
On other GTD's I have seen, these holes are fitted with bleed valves. I have tried several local plumbers merchants, but the bleed valves they have are fitted with a slightly different thread.
Can anybody tell me where in the UK I can find bleed valves that will fit the standard GTD radiator?
Thank you.
Cobra John is offline
Old 09-14-05, 10:04 AM   #2 (permalink)
Neal's Avatar
Neal
8 Tenths
GT40: GT40 NZ
Rep Power: 15 Neal is a glorious beacon of light
Re: Radiator bleed valve
Not sure about your specific size but Summit Racing offers a Moroso piece. http://store.summitracing.com/default.as...t=egnsearch.asp
I ran a 3/16 ID tube from the top radiator plug back to the top of the surge tank. It remains open all the time and allows any air to escape. No cooling issues.
Neal is offline
Old 09-18-07, 06:35 AM   #3 (permalink)
Brian McCarthy's Avatar
Brian McCarthy
GT40: GTD
Rep Power: 11 Brian McCarthy is a glorious beacon of light
Let's put this back up for a look. I'd like to use these fittings in my GTD radiator for purging air back to the coolant swirl tank (for lack of a better name)but the plugs are solid. Has anyone found something that will screw into the hole to which I can attach a bleed line?
I know I can pull the radiator and solder a fitting in, but I'd prefer the simple route if I can get there from here.
Many Thanks
Brian
...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...BRM Pin Drive wheels
...Gulf livery
Brian McCarthy is offline
Old 09-19-07, 04:37 PM   #4 (permalink)
Howard Jones's Avatar
Rep Power: 25 Howard Jones is a jewel in the rough
My GTD radiator was threaded for 1/4 pipe. An-4 to 1/4" pipe fitted right up. I T'ed them both and ran a 1/4" line back to the surge tank. I also tapped and fitted two 1/4" An fitting on the two rear water passages on the intake mainfold and ran a line to the surge tank.
This system will self bleed and solve most of the AIR problems in a GTD system. I have also replaced the thermostat with a disk that has a 5/8" diameter hole in it. I can now drain the system and apon refill simply let it self bleed. No muss no fuss.
Howard Jones is offline
Old 09-19-07, 10:29 PM   #5 (permalink)
Brian McCarthy
GT40: GTD
Thanks Howard, I have fitted the intake bleeds as is common practice now. What I'll likely do tomorrow is to investigate the radiator fitting that the plugs screw into and see if there is enough meat in there to drill and tap to a pipe thread.
Brian
...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...Gulf livery
