Old 11-15-05, 03:05 PM   #1 (permalink)
alanrayner
South Africa
GT40: Scratch Build
Rep Power: 7 alanrayner is on a distinguished road
Flywheel fabrication
Dear All
I have been reading this forum for a few years now, however this is my very first posting. Hopefully someone has an answer for my problem.
I am currently rebuilding a ford 302 engine (year 1980) which will used with an Audi 016 transaxle. I am in the process of designing a flywheel, however I need some guidance as to where the counter balance (50 Oz) needs to be located relative to TDC and how does the weight of the counter-balance on the flywheel relate to the distance from the centre of the crankshaft.
The engine will be balanced in a workshop, however I would like to have the counter-weight in place before the more precise balancing takes place.
I would appreciate any advice.
Alan
alanrayner is offline
Old 11-15-05, 06:26 PM   #2 (permalink)
MikeDD's Avatar
MikeDD
GT40: DRB
Re: Flywheel fabrication
My advice is to purchase a flywheel from whomever supplies your adapter plate. www.kennedyengineering.com sells a nice
kit for this application...but since you are in South Africa, you may as well try Superformance.
MikeD
MikeDD is offline
Old 11-17-05, 07:22 AM   #3 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Why not speak to John Spence at Auto Futura? They do an adptor plate and flywheel etc for the 016, I believe.
Brett
brettmcc is offline
Old 11-27-05, 02:31 PM   #4 (permalink)
alanrayner
South Africa
GT40: Scratch Build
Thanks for the advice guys. I will be making a few phone calls shortly.
Alan
Old 12-01-05, 04:46 PM   #5 (permalink)
Lukas
Austria
GT40: None yet...
Rep Power: 6 Lukas is on a distinguished road
If you are rebuilding your 302, have you thought about putting a stroker kit in it? You might want to do that since this will cost only slightly more if you have to get new pistons, rings, etc anyway, have the rods resized, crank ground etc. 331 or 347 stroker kits can be had complete for about $1100-$1400 including pretty much everything.
An added advantage would be that you could get the kit in a zero balance which would save you money for balancing and solve the whole flywheel counterweight issue.
Lukas
Lukas is offline
Old 12-05-05, 01:12 PM   #6 (permalink)
alanrayner
South Africa
GT40: Scratch Build
Lukas
Thanks for the advise. Unfortunately I have already bought new pistons, conrods etc.. and I've just had the crank machined. So it looks like there is no turning back on the engine front.
I have started work on my new flywheel and I will shortly be passing the drawings on to the engine balancer for their comments.
Alan
Old 12-07-05, 10:10 AM   #7 (permalink)
candc's Avatar
candc
GT40: tornado ts 40
Rep Power: 7 candc is on a distinguished road
i was reading a racecar engineering mag that came into work today there is a flywheel manufacturer in it called KAITEN PERFORMANCE PRODUCTS no connection their web site is www.kaitenproducts.com they may help not sure were they are based
candc is offline
