| Re: filters a good Idea Ross,
sorry to here about that. I'm supprised at how many members are running without air cleaners. They might not look as cool with them on, but they sure save on bearings, and in your case if a big chunk gets in you loose things like valves and pistons. It's usually the .010mm size particals that absolutely tear motors up. They are so small they get right into everything including bearings and between pistons and cylinder walls, tear up cam shafts, etc........
There's no way I'd spend all that money on a motor and then not put a good air filter on it. Well at least all motors have oil filters to stop some of what is getting past the lack of air filteration.
Just my [img]/ubbthreads/images/graemlins/twocents.gif[/img]
good luck with new setup. |
