> 1. Have to run the TR8 Federal injection system. It is the flat top plenum
> (to clear the hood).
> 2. I could probably get away with the twin plenum from the SD1 Vitesse, no
> one would know, but it would be cheating.
Both the twin plenum Vitesse and single plenum Range Rover intake will clear
the stock TR8 hood. I think I have some information on a fairly healthy
TR8 (or was it an MGBV8?) that ran the TR8 Federal intake set-up. I'll see
what I can dig up.
If you are still running the stock TR8 oil pan, you might want to remove
the extension that goes from the pan to the bellhousing. Ted at TSI ran
TR8's in showroom stock and said it would eventually crack the oil pan.
> 3. Can't run the Buick 300 heads, although everyone agrees those are the best
> "early" heads for the 3.5/3.9 (before Wildcat and others started doing their
> own castings).
I'm pleased with the flow bench results on mine. The exhaust to intake
flow ratio is good and the low and mid-lift numbers are excellent. These
heads are destined for my street TR8. It was important to leave adequate
wall thickness so we didn't go crazy on the port job but the results are
quite good for such a small valve head and should support my HP goals.
Valve Buick 300 Exh/Int
Lift 1964 ratio
(inch) aluminum (%)
ported
Int Exh
1.775" 1.5"
0.100...66....47....71.2
0.150...99....82....82.8
0.200..129...104....80.6
0.250..155...119....76.8
0.300..174...130....74.7
0.350..187...139....74.3
0.400..191...146....76.4
0.450..194...150....77.3
0.500..196...152....77.6
0.550..200...153....76.5
0.600..200...153....76.5
Flow numbers were taken on a Superflow bench at 28" H2O with a clayed intake
radius but no exhaust pipe. Heads were ported by Jon Carls of JDC Engineering
in Minonk, IL. 6000 Series Ferrea Buick V6 Stage 1 valves were used. Intake
valves are part number F6238 (1.775" head diameter, 11/32" stem, 4.735" long
with a 0.271" tip). Exhausts are part number F6237 (1.5" head diameter, 11/32"
stem, 4.735" long with a 0.254" tip). Intake head shape is a 10 degree Super
Flo. Exhaust is a 29 degree tulip. Ferreas 6000 Series valves are competition
parts suitable for solid roller cams. The larger valves required larger seats,
p/n 30903 for the intake and p/n 30647 for the exhaust.
I'm doing a stroker Rover/Buick V8 for my TR8:
http://www.bacomatic.org/gallery/dan-tr8
Should be around 294 cubes:
ported Buick 300 aluminum heads (being ported)
adjustable roller rocker set-up (new shafts, Harland Sharp rocker arms)
Rover 4.0L cross-bolted block (align-bored to take to Buick 300 bearings)
Rover/Buick forged rods with ARP bolts (or possibly SCAT SBC I beam rods)
aluminum flywheel
mini-starter
TR8 oil pan and scraper
Willpower single plane intake with EFI bungs
large tube TR8 headers
> Woody is a great resource; he built one of my short blocks. I'll start there.
I'm getting ready to purchase a set of 15" Compomotive rims from Woody.
Need to get rid of those dinky 13" rims so I can mount some decent rubber.
Woody also has a 12" Wilwood front brake package for the TR8 that I plan
to install, along with a narrowed Ford 8.8" disc brake rear with limited
slip.
If you're interested, I'd like to discuss suspension and other TR8-related
topics with you some time.
Thanks,
Dan Jones
P.S. There are some Buick/Rover images and info at:
http://www.bacomatic.org/gallery/album10
that you might be interested in looking at, including a set of radical welded
and ported Rover heads, a lengthy article on racing Buick/Olds 215's including
the Mickey Thompson Indy effort and Lance Reventlow's Scarab, etc.
