Old 05-25-06, 02:42 PM   #1 (permalink)
France
Rep Power: 5 Peruch is on a distinguished road
Thumbs up 306 dyno results!!
2.87X4.125 dart aluminium block
pro top line iron head 2.02X1.60 flow:311@ .600 213@.600
51 IDA's Weber
5.400 rod, 11.0 CR
TQ HP
4000 373 284
4200 357 286
4400 377 316
4600 404 354
4800 410 375
5000 404 385
5200 403 399
5400 405 416
5600 405 431
5800 401 443
6000 397 453
6200 391 462
6400 386 471
6500 382 473
6600 367 461
Peruch is offline
Old 05-25-06, 09:21 PM   #2 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Nice numbers !
I am shooting for something like this with the rebuild of my old engine as a 331, AFR 165's, 10.5:1, etc. I hope it turns out as well as yours did.
Kind Regards,
Peter D.
DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl
delaneyp is offline
Old 05-25-06, 10:25 PM   #3 (permalink)
salmjo1's Avatar
salmjo1
3 Tenths
Rep Power: 7 salmjo1 will become famous soon enough
Question
Can I ask a novice question (Ok, several)? I want to see if I understand - the block is a little over bore (4.125 vs 4.00) with a shorter stroke (2.87 vs 3.00). So I am assuming: similar displacement, but the shorter stroke helps with reciprocating forces and rod angle..? What are the real world benefits? Will it inherently rev faster; will it be easier to handle higher revs? In other words, what are the benefits over a 302?
Also, why the aluminum block but iron heads? Stronger?
Obviously this works - that is impressive output for displacement.
Thanks for the help.
-J.
salmjo1 is offline
Old 05-26-06, 03:45 AM   #4 (permalink)
France
-J.
Restricted rules, must have original stroke and iron heads with stock iron rockers!!!
Peruch is offline
Old 05-26-06, 09:31 AM   #5 (permalink)
Mark Worthington's Avatar
Mark Worthington
GT40: Massachusetts
Awesome! I was thinking you used iron heads to allow higher compression...
Mark
347, MoTeC EFI, pin drives, leather, etc.
Mark Worthington is offline
Old 05-26-06, 11:25 AM   #6 (permalink)
France
exactly!!!
Peruch is offline
Old 05-27-06, 05:42 PM   #7 (permalink)
salmjo1's Avatar
salmjo1
3 Tenths
Ah... Thanks.
salmjo1 is offline
Similar Threads
347 dyno results ricadona GT40 Tech - Engines/Induction/Exhaust 25 09-27-04 01:14 AM
Dyno results w/ G-W heads MBelcher GT40 Tech - Engines/Induction/Exhaust 4 07-25-04 01:33 PM
Dyno results for Levy Racing Engine Bart Carter All GT40 4 10-03-03 09:13 AM
Dyno Results CCX33911 GT40 Tech - Engines/Induction/Exhaust 3 03-23-03 11:46 AM
351C dyno results DaveWharran All GT40 2 03-17-02 03:59 PM
