Old 02-03-07, 07:59 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Ron Earp's Avatar
Retiree
Can someone run a engine dyno program......
Our beloved TR8 is about halfway through a head swap with some flowed and ported heads. I would like to know what sort of flywheel hp that is the maximum theoretically possible for the motor, if someone can calculate that or estimate it.
I'm not sure all of the parameters that you'd need, but here are some basics:
Compressoin 8.6:1
Displacement 3.5L, 215 inches
Bore 3.5" x 2.8" stroke
Max valve lift 0.400"
Now, don't laugh, but the best the head will flow, with intake, is 70 cfm/min on the intake side at 0.400" lift. I have the flow numbers by lift and will post them.
Max RPM will be about 6000. Head design is decent, 1.5" primaries, about 25 to 30 inches long to collector, four into one on each side, then joining into a single 3" exhaust. No muffler. All mandral bends.
What else would be needed? Induction is two Zenith Strombergs, each one 1.75" bore, and they definitely aren't the limiting factor on the motor, that crappy intake is for sure.
Ron
Ron Earp is offline
Old 02-03-07, 08:59 PM   #2 (permalink)
sfm6s
Rep Power: 4 sfm6s is a glorious beacon of light
Re: Can someone run a engine dyno program......
Well using what info you give I get Bhp 237/ Tq 207 @ 6000 , peak Tq 228 @ 4500. Usefull info to make it more accurate would be valve sizes, lifter type, dual or single plane manifold, cam intake and exhaust duation @ .050 and
lca. The prog I have is crude but it does the job.
sfm6s is offline
Old 02-03-07, 09:59 PM   #3 (permalink)
Ron Earp's Avatar
Retiree
A poor dual plane intake, and hydraulic lifters, flat tapets. I'll get the cam specs and flow numbers tomorrow AM. Thanks for giving it a shot!
Ron
Ron Earp is offline
Old 02-03-07, 10:56 PM   #4 (permalink)
ahirsbrunner's Avatar
ahirsbrunner
Administrator
GT40: RCR-40 #24
Rep Power: 8 ahirsbrunner has disabled reputation
I know these programs vary a lot in their accuracy, so here is what I got (using only the one flow value) that you can average into the mix...
I noticed after I ran the numbers that you mentioned open headers into 3" collectors, this boosted the #s to 183HP@5250/198TQ@3500
Al
P.S. I know you probably don't care, but it should run a 15.29 Quarter mile @ 87.6 MPH based on published weights (the car's, and yours )
ID:	17593   Click image for larger version
ID:	17594   Click image for larger version
ahirsbrunner is offline
Old 02-04-07, 01:22 AM   #5 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 23 jac mac has much to be proud ofjac mac has much to be proud of
Wink Re: Can someone run a engine dyno program......
I dont have a program, other than the space between my ears,but already it has told me your primaries are too short. Now if your care to divulge your valve timing events( @ the seat ) and tell me that 8.6/1 comp is a misprint I could work out what you need. In any event you should be able to extract up to 220/230 hp before the carbs @1.75" ea become a problem.
cheers
Jac Mac
jac mac is offline
Old 02-04-07, 08:41 AM   #6 (permalink)
Ron Earp's Avatar
Retiree
Al, you might be about right on! The last rear wheel dyno event recorded 159 rear wheel hp, and about 180 ft/lbs of torque, at 5200 and 3500 respectively. Al, did that program have stock TR8 cam info etc in there?
Jac Mac I'll get the numbers when Jeff brings back over the sheets. We've got to finish up the head swap today, right now there are TR8 bits littering my garage and we're on a tight schedule. I'll measure the primaries with a tape instead of guessing. They might be longer than I think. Or shorter.....And no, it is 8.6 CR........
R
Ron Earp is offline
Old 02-04-07, 10:56 AM   #7 (permalink)
ahirsbrunner
Administrator
GT40: RCR-40 #24
Hi Ron,
No stock info for the TR8 cam, but I will see what I can dig up. Most simulators (at least in the range that I can afford) are really best used to compare the relative difference between scenario A vs B, and are not that great at giving you a right on-the-money HP and TQ curve.
If I had the opportunity to choose, using the program in "the space between Jac Mac's ears" is what I would go with!
Al
Old 02-04-07, 11:18 AM   #8 (permalink)
ahirsbrunner
Administrator
GT40: RCR-40 #24
Most of the "stock" replacement cams for the TR8 I have found fall into the range below.
Al
ID:	17613   Click image for larger version
ID:	17616   Click image for larger version
Last edited by ahirsbrunner; 02-04-07 at 12:39 PM. Reason: Added new dyno run with above cam data and changed to performance porting setting
Old 02-04-07, 03:21 PM   #9 (permalink)
jac mac's Avatar
jac mac
New Zealand
Why are you fitting the heads then? Have you got the piston to head clearance down to around 0.040". You need to deck the block to obtain this dimension- once that alloy block warms up the deck clearance will increase.
Jac Mac
jac mac is offline
Old 02-04-07, 07:46 PM   #10 (permalink)
Ron Earp's Avatar
Retiree
Hey Al,
your cam numbers match what it in the TR8 book so that has to be it, but I'll find all the real specs for it. Compression ratio has been calculated and heads cc'ed, gasket taken into account etc - it is right at 8.6:1, actually a tiny bit over like 8.62:1, but that is the max allowable. The primaries are actually approximately 33-35" long, or thereabouts, not what I estimated eariler. Pulled a tape down on them when I was undoing the exhaust today.
The intake flow is like this:
0.050 11.92
0.100 24.35
0.150 39.32
0.200 46.64
0.250 55.04
0.300 59.07
0.350 62.84
0.400 69.26
The exhaust flow is not much different from the intake flow on the bench.
Ron Earp is offline
Old 02-04-07, 09:16 PM   #11 (permalink)
ahirsbrunner
Administrator
GT40: RCR-40 #24
Hi Ron,
Using your flow numbers and bumping up the CR to 8.62 gave these results (1 more lb-ftTQ)...
Al
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-tech-engines-induction-exhaust/20707-can-someone-run-engine-dyno-program.html
Posted By For Type Date
GT40s.com This thread Refback 02-03-07 08:25 PM
