Old 08-20-07, 08:41 AM   #1 (permalink)
more_ghz_project's Avatar
more_ghz_project
Romania
GT40: i wish....
Rep Power: 4 more_ghz_project is on a distinguished road
8 stack fuel injection, need some help !
i have a friend an a corvette forum who has bought an 8 throttle body intake
and he wants to know what options he has for the fuel injection computer.
so i figured since you guys use this setup, this would be the best place to ask
he also asks about what filters he could use over the stacks
more_ghz_project is offline
Old 08-20-07, 07:02 PM   #2 (permalink)
Fatal Attraction's Avatar
Fatal Attraction
GT40: Ex-DRB #35
Rep Power: 23 Fatal Attraction has a spectacular aura about
Re: 8 stack fuel injection, need some help !
Inglese filters, Motec computer.
Nice looking crossram manifold!
Ex-Gt40 Australia #35
351W 425HP
TWM 8 stack TBI
MOTEC M4
G50/Quaife LSD
Fatal Attraction is offline
Old 08-20-07, 09:29 PM   #3 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
TWM and iTG both make good filtration systems that could be fitted (a search of either on Google will yield results).
ECUs are many and varied, I too like Motec, pricey, but versatile in my opinion.
Other good alternatives are available too, from almost DIY systems such as megasquirt to major players such as Acell, Electromotive, DFi, MSD to name but a few.
Is the currently installed motor injected?
If not, then also consider the high pressure fuel requirements, pumps/returns, swirlpot(s), pressure regulator, additional sensors for Water Temp, air temp, throttle position, Manifold pressure (or MAF to airboxes) + a crank trigger and if running sequential, a cam position signal too. Consider also the ignition requirements, to keep a distributor, or to switch to a multi-coil setup (coil per plug or wasted spark). The list goes on and depending on your own experience/willingness to 'dive in', careful consideration should also be given to the availability of experienced assistance for setup/tune/problem diagnosis.
Hope I haven't muddied the waters too much - there's a lot to consider but a well injected engine is a great experience indeed! Just ask anyone who has driven one...
regards
Paul Thompson
p thompson is offline
Old 08-20-07, 09:40 PM   #4 (permalink)
MReid's Avatar
MReid
4 Tenths
GT40: RCR Mk1
Rep Power: 6 MReid is a glorious beacon of light
I used Redline by Weber on my stacks. It has inputs for all the appropriate sensors and can control both fuel and spark if you want. It also offers many tuning options including the ability to mix different percentages of TPS with the fuel map. You need a laptop, but the screens are very clear and easy to use. Here's a pic:
Have fun with your build! - Mark
FFR Daytona Coupe
RCR Gt40 Mk1 in the garage, and underway!
MReid is offline
Old 08-24-07, 05:00 AM   #5 (permalink)
more_ghz_project
Romania
GT40: i wish....
thanks for the help you three !
