Old 09-06-07, 10:22 AM   #1 (permalink)
markg
Rep Power: 3 markg is on a distinguished road
5 bolt/6 bolt
What is the significance of a 6 bolt belhousing vs. 5 bolts on a 1966 289 block?
markg is offline
Old 09-06-07, 10:39 AM   #2 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: RCR40 - #45
Rep Power: 23 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Re: 5 bolt/6 bolt
I thought that all the 66 and later blocks were 6 bolt.
Not sure of what you mean in terms of significance but the bellhousing for a 5 bolt block will not properly bolt up to a 6 bolt block..
Regards - Randy
Big-Foot is offline
Old 09-06-07, 04:18 PM   #3 (permalink)
toy264's Avatar
toy264
Rep Power: 6 toy264 will become famous soon enough
Re: 5 bolt/6 bolt
I'm pretty sure Ford made the change from 5 to 6 bolt bellhousings in August of 64. The 5 bolt blocks came with a 160 tooth flywheel and 10.5 clutch and the bellhousing was smaller. The 5-bolt bellhousing also used 3/8" bolts while 6-bolt units use 7/16". The timing chain cover bolt pattern, and therefore the water pump’s, also changed about that time, but I don’t remember exactly when.
John
toy264 is offline
Old 09-06-07, 04:19 PM   #4 (permalink)
toy264's Avatar
toy264
Re: 5 bolt/6 bolt
Oops, double click.
toy264 is offline
Old 09-06-07, 04:55 PM   #5 (permalink)
Doc Watson's Avatar
Doc Watson
5 Tenths
GT40: Replica Mk I
Re: 5 bolt/6 bolt
all 289 blocks up to the end of 64 had 5 bolt bellhousing patterns. Block numbers will be...
C3AE-N
C40E-C
C40E-F
C4AE
C4DE
As of 1965 all 289's have a 6 bolt bellhousing.
C5-AE-N
C50E-A
C6AE-C
The 289 hipo block is exactly the same block as the standard 289 with the difference being thicker main-bearing caps. Although the block numbers are not all the same...
289 hipo 5 bolt
C30E-B
C40e-B
289 hipo 6 bolt
C5AE-E
I need to get out more.....
Doc Watson is offline
Old 09-06-07, 05:06 PM   #6 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 23 jac mac has much to be proud ofjac mac has much to be proud of
Re: 5 bolt/6 bolt
I think it was in mid 65 that change was made from 5 to 6 bolt, going by HP part numbers, C40Z-6010-C for 5 bolt-- C5OZ-6010-C for 6 bolt.
Timing bolt cover pattern on block is same , but design of cover in pump attach area is different to accept later pumps with sandwich plate ( early cover had direct contact with coolant in impeller cavity & was subject to erosion- also provision was made for oil fillertube to intersect with cavity from timing chain area to valley.)
So if your block cast number is C6--- then you have a 6 bolt 289.
Jac Mac
jac mac is offline
Old 09-06-07, 06:13 PM   #7 (permalink)
toy264's Avatar
toy264
Re: 5 bolt/6 bolt
Jac Mac
Yep, I was wrong. It was '65 for the 6 bolt. I should have done a little Googling. My 6 bolt 289 had the old style timing chain cover with no water pump backing plate. And they did erode!
John
toy264 is offline
Old 09-06-07, 11:25 PM   #8 (permalink)
markg
Re: 5 bolt/6 bolt
Thanks guys..
markg is offline
