Whats this red light for. Hi all, some help required. I own a 1990 factory built gtd40 with the gtd aircon package fitted. I had to change leaking water pump. On completion of job when I switched on to start car to bleed system I found that apart from ignition light the right hand red light located in centre of dash above the aircon and fan control switches has also now come on and stays on when car is running, what is this red light for ?.
In this centre cluster there are three lights -- l/hand Red ?. --centre Yellow for rad fans. -- r/hand Red which has come on ?.
Can you tell me what the left and right lights are for and why the r/hand red one has now come on.
The aircon has not worked since I got the car, I just use the blower fan and fresh air vents, but this red light has not come on before. |
