Old 10-18-07, 10:53 AM   #1 (permalink)
simonjrwinter's Avatar
simonjrwinter
serial GT40 owner
GT40: GTD
302 build up
trying to put together a 302. put in crank and pistons, but as I tighten the rod bolts the crank gets MUCH too tight. The clearances are ok, where am I going wrong?
Simon
GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD.
simonjrwinter is offline
Old 10-18-07, 11:35 AM   #2 (permalink)
jasonlycett
GT40: Worcestershire,
Rep Power: 4 jasonlycett is on a distinguished road
Re: 302 build up
Hi Simon
I had a that same problem when i built mine some time ago. I found one of the conrod's was out of round.
Try checking that
jasonlycett is offline
Old 10-18-07, 12:22 PM   #3 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 20 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Re: 302 build up
One of the following;
If you've already checked the clearances with a micrometer on both the crank pin as well as the assembled rod - I think you better check to make sure that the rods were installed correctly on the piston - or - that you're installing the piston/rod assembly into the correct hole with the correct orientation.
Hint:
The chamfer on the big end of the rods needs to point to the outside and not towards the neighboring rod. This chamfer corresponds to the chamfer cut into the side of the crank pin.
Regards - Randy
Big-Foot is offline
Old 10-18-07, 12:25 PM   #4 (permalink)
simonjrwinter
serial GT40 owner
GT40: GTD
Smile Re: 302 build up
OK, thanks chaps, sorted it now. I had the very last rod cap on back to front. Don't think any damage was done. Turned it round and all torqued up now, everything seems nice and smooth...phew!
Thanks Randy you wuz right!
Old 10-18-07, 12:52 PM   #5 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
Rep Power: 7 jonathans is just really nice
Re: 302 build up
Make sure you have not put a rod in the wrong place or turned a rod or its cap backwards.
RCR GT40
Build Page: https://home.comcast.net/~jonathanstrain/
jonathans is offline
Old 10-18-07, 01:19 PM   #6 (permalink)
YerDugliness
GT40: Yellow Wix MKII
Rep Power: 8 YerDugliness will become famous soon enough
Re: 302 build up
I had a similar problem with a SB Chebbie one time, but all I did was take out the crank, left the rods/pistons in the block, and replaced the rod/main bearings. Put it back together and it was WAY too tight. I checked all the clearances, and they were OK. Finally figured out I had bent the crank--I had been stupid enough to stand it up on it's rear flange and it fell over. It never dawned on me that would bend it, but it did, and it was useless (as are, I am now convinced, all Chebbie products).
Glad it worked out better for you!
Dugly
YD,E./PNB
Retired and attempting to age disgracefully
YerDugliness is offline
Old 10-20-07, 07:45 PM   #7 (permalink)
wment
GT40: Valkyrie
Rep Power: 3 wment is on a distinguished road
Re: 302 build up
Since it is a rod, I would check the rod end for being round. A main bearing doing that could mean a bent crank or bearing alignment.
wment is offline
