| Notices | Hi member,
Enjoy the forum!
11-29-07, 01:15 PM
#1 (permalink)
| | simonjrwinter serial GT40 owner
Rep Power: 24  | 302 front cover oil seal Is it installed from the inside or outside? I've installed it from the inside of the cover but it hits the oil slinger. Have I put it in the wrong way?
Simon
__________________ GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD. |
11-29-07, 01:25 PM
#2 (permalink)
| | Big-Foot Gold Supporter
Join Date: Jan 2007 Location: Minneapolis, MN GT40: Replica
| Re: 302 front cover oil seal I always install it from the outside and get the face of it flush with the lip on the cover.. I use a piece of 2x4 wood to drive it in. I did measure the hole once a number of years ago and found the inside to be a slightly smaller diameter than the outside. As I recall the taper was on the order of .002" to .003".. Not much - but something... |
11-29-07, 01:30 PM
#3 (permalink)
Rep Power: 15  | Re: 302 front cover oil seal It depends on which year your timing cover was made.
There are two different seal configurations.
Some early seals were inserted from the rear and later ones from the front respectively.
__________________ Cordially, James MKI monocoque. XE' 289 short blocks, C6FE heads, Webers, ZF Graviner Fire Suppression |
11-29-07, 02:03 PM
#4 (permalink)
Rep Power: 24  | Re: 302 front cover oil seal It's an '86 engine, I now think it's meant to install from the outside.
Thanks guys
11-29-07, 02:38 PM
#5 (permalink)
| | jac mac 10 tenths
Rep Power: 18   | Re: 302 front cover oil seal If you are still using the large dia oil slinger with a double row chain assy you will need to trim the slinger or obtain a smaller dia version from late model engines. As a point of interest I usually mod the early covers to take the later ( external lip ) seals.
Jac Mac |
11-29-07, 02:54 PM
#6 (permalink)
| | MReid 4 Tenths
Rep Power: 6  | Re: 302 front cover oil seal Probably goes without saying, but I'll say it anyway! Loosely install the front cover bolts and then install the balancer fully. This centers the seal around the balancer. Now torque the front cover bolts to spec. Helps ensure you get no oil leaks and long service out of the seal.
Mark
__________________ Have fun with your build! - Mark FFR Daytona Coupe RCR Gt40 Mk1 in the garage, and underway! |
11-29-07, 03:44 PM
#7 (permalink)
| | jac mac 10 tenths
Rep Power: 18   | Re: 302 front cover oil seal Quote:
Originally Posted by MReid Probably goes without saying, but I'll say it anyway! Loosely install the front cover bolts and then install the balancer fully. This centers the seal around the balancer. Now torque the front cover bolts to spec. Helps ensure you get no oil leaks and long service out of the seal.
Mark | Only if you have the block standing on the bell housing face, gravity will cause the cover to drop slightly otherwise. Late model blocks/covers eliminate the concern with dowels for location. Yeh, I know, Im a fussy old bastard.
Jac Mac |
11-29-07, 05:03 PM
#8 (permalink)
| | MReid 4 Tenths
Rep Power: 6  | Re: 302 front cover oil seal Actually, you fussy old bastard  , you bring up something that has bugged me for a while. The last three Ford racing crate engines I bought didn't have the dowels in the front cover, but the replacement front cover did. What's up with that?
11-29-07, 06:39 PM
#9 (permalink)
| | jac mac 10 tenths
Rep Power: 18   | Re: 302 front cover oil seal Mark , while Im fairly passionate about Ford & racing, its been about two decades since I gave up trying to work out their reasons for some of the things they do, actually probably much longer when you consider while they built the most sensible blocks with good oiling etc,yet poor cylinder heads in terms of making power [Windsor]on one side of the river, the folks on the other side [Cleveland] were building cylinder heads cabable of making huge HP & what did they do, install them on a block with a flawed oiling system & weak cylinder walls that cracked every time there was a hint of detonation. Then they put both into production to compete against one another. The only good thing that came out of that was the Boss 302 and the Hot Rod guys who persevered to where we are today with an aftermarket reincarnation of what we could/should have had in the early 70's.Go Figure!!
Jac Mac |
11-29-07, 07:52 PM
#10 (permalink)
| | Gary Kadrmas Silver Supporter
Join Date: Sep 2006 Location: Oregon, USA GT40: Not yet, but so
Rep Power: 12   | Re: 302 front cover oil seal If you look further into history, you will find decades of the same thing happening over and over at Ford. So what is new....nothing.
__________________ Gary Kadrmas
___________________
Owner of CSX-2075 for over 30 years, and wanting a GT40 for over 20 years |
11-30-07, 02:59 AM
#11 (permalink)
Rep Power: 24  | Re: 302 front cover oil seal Quote:
Originally Posted by jac mac If you are still using the large dia oil slinger with a double row chain assy you will need to trim the slinger or obtain a smaller dia version from late model engines. As a point of interest I usually mod the early covers to take the later ( external lip ) seals.
Jac Mac | DAMN! just installed the front cover and water pump before realising that the slinger seemed a bit tight against the front cover. Damn! guess the whole lot will have to come off again.Damn
Simon
11-30-07, 03:59 AM
#12 (permalink)
| | jac mac 10 tenths
Rep Power: 18   | Re: 302 front cover oil seal Life can be a Bit**!
Jac Mac |
11-30-07, 03:21 PM
#13 (permalink)
| | Rick Rookie
Rep Power: 2  | Re: 302 front cover oil seal The covers for early and late engines as mentioned are different, the seals are different too. However they will interchange (diameters) but the later one has a flat flange on the outer diameter and is only intended to be used on the later cover. |
12-06-07, 02:41 PM
#14 (permalink)
| | Jay P Rookie
Rep Power: 1  | Small block Oil Slinger I checked with my local parts dept about the oil slinger for small blocks, and they said that the last engine to use one was in the '79 or '80 model year, and they were pulled from the catalog in '95 or so. Apparently, they,(Ford) feel that they are now unnecessary. And now that I think about it, I haven't seen one in quite a while on the engines I've torn down. John |
