and once again the drops were forming at the core where the tubes enter the epoxy ends.
This can be a problem with epoxied radiators that are mounted solidly to the chassis. Most modern rads are mounted using some sort of rubber saddle at both the top and bottom to sort of isolate the rad from vibrations and twisting forces in the chassis, and let it float. I lost two epoxied radiators in a Mustang, they were mounted solidly, I later switched to a "Be Cool" fully welded rad and never had a problem. I'm using a Rod Davis welded radiator in my Cobra also without any issues. If you can't find a radiator that fits properly, Ron Davis will probably make a radiator to your specifications. I was also told by several radiator shops that the epoxied radiators are not repairable and were to be considered "throwaways" However, this could be because they just didn't want to deal with them. John
