Old 02-09-08, 07:55 AM   #1 (permalink)
Nick Brough's Avatar
Nick Brough
GT40: ford 351W G50
Rep Power: 3 Nick Brough is on a distinguished road
351W engine rebuild advice
Hi,
I have come to the point were I need to fit my pistons to my 351W block and need some advice please.
As I understand it the pistons are numbered 1-4 on the right hand (offside in the UK) with number 1 at the water pump end, and 5-8 on the left hand side with 5 at the water pump end.
The book I have says the pistons are notched and to put the notch facing forwards, but I have new pistons fitted which are unmarked so how do I determine which way round they should go.
The conrods are numbered 1-8 so do I make sure all the numbers are on the inside ( middle of the block) for both banks.
Nick
Nick Brough is offline
Old 02-09-08, 10:20 AM   #2 (permalink)
collaudatore's Avatar
collaudatore
GT40: CAV GT40
Rep Power: 2 collaudatore is on a distinguished road
Re: 351W engine rebuild advice
Hi Nick,
see the attachment. I found it by Ford 302 HO 351W-Windsor 5.8 400 V8 Engine Specs-Torque Specs-Cylinder Numbering-Firing Order-Distributor Rotation
Best regards
Martin
collaudatore is offline
Old 02-09-08, 10:40 AM   #3 (permalink)
Gordon Levy's Avatar
Gordon Levy
Rep Power: 10 Gordon Levy has a spectacular aura about
The easier way to make sure they are installed correctly is to look at the crank end of the rad. The sides of the opening has a small chamfer on one side and a large chamfer on the other. 1-2-3-4 have the large chamfer facing forward and 5-6-7-8 have the large chamfer facing back when installing.
Pro Builder www.levyracing.com www.gofastforum.com
Gordon Levy is offline
Old 02-09-08, 11:09 AM   #4 (permalink)
Nick Brough
GT40: ford 351W G50
Martin,
Thanks for the info it will be very useful. Gordon is "facing forward" towards the water pump end of the engine.
Nick
Old 02-09-08, 03:39 PM   #5 (permalink)
jac mac's Avatar
jac mac
Rep Power: 18 jac mac has much to be proud ofjac mac has much to be proud of
Smile Re: 351W engine rebuild advice
I think Gordon would have meant 'Crank end of the Rod' to look for the chamfer which clears the radius at each side of the crank pin.
The attached drawing shows the correct positions of the valve notches which should help along with gordons info to ensure that you have both piston & rod fitted correctly.
In some very rare cases pistons can also be specific to left or right bank if the maker still incorporates pin offset, but this info is usually clearly marked or provided with the pistons.
Jac Mac
jac mac is offline
Old 02-09-08, 05:56 PM   #6 (permalink)
Nick Brough
GT40: ford 351W G50
Hi all,
Thanks for all your help. everything seems to have fallen in place now, I thought I had it worked out but wanted to double check. Now arranging the pistons with the chamfer as described ans as per Jac Mac's diagram I have all the numbers on the conrods facing inwards which is what I was after.
Funnily enough the F's stamped on the side of my new pistons all face forwards towards the distributer end now as well!!!
Nick
