Old 02-20-08, 01:48 PM   #1 (permalink)
toy264's Avatar
toy264
Rep Power: 6 toy264 will become famous soon enough
Radiator caps and pressures
When you have two caps in the cooling circuit, one on the radiator and one on the header tank, is it better to use a non venting cap on the radiator (or just seal the vent tube) and a pressure relief cap on the header, or a pressure relief cap on both, with the header cap having the lower vent pressure?
toy264 is offline
Old 02-21-08, 12:43 AM   #2 (permalink)
Rick
Rep Power: 4 Rick is on a distinguished road
Re: Radiator caps and pressures
Radiator cap must vent and have the lower presure, surge tank to have the higher cap rating.
Rick is offline
Old 02-21-08, 03:52 AM   #3 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 18 IanAnderson is a jewel in the rough
Rick
I'd say the exact opposite
Fill the radiator and have a non pressure cap on it (sealed)
Then in the header at the highest point in the system put the pressure cap on so when the water expands it expels any air first so the hot water will fill the system and header
The other way around and your radiator could get air in and not necessarily bleed it back to the header.
IanAnderson is offline
Old 02-21-08, 03:40 PM   #4 (permalink)
toy264's Avatar
toy264
Thanks Ian. My intention is to put a spigot at the high point on the radiator, as suggested on another thread for bleeding, but I didn't know if it was customary to add a secondary pressure relief to back up the one on the header tank. Sounds like a belt and braces approach that isn't needed.
toy264 is offline
Old 02-21-08, 11:36 PM   #5 (permalink)
prre's Avatar
prre
Silver Supporter
GT40: GT40 Developments Chassis, Tornado Bodied
Rep Power: 7 prre is on a distinguished road
I agree with Ian. For a bleed you could take a small pipe off of a high point on the radiator and run it to the header tank. I also have on mine a small pipe coming off of the top of the retun cooling pipe just before the engine, to bleed any bubbles, again routed to the header tank. both bleed pipes come in low on the header tank.
Paul R
Tornado Bodied GT40 Developments Chassis
prre is offline
