Old 04-27-08, 03:37 PM   #1 (permalink)
simonjrwinter's Avatar
simonjrwinter
serial GT40 owner
GT40: GTD
Rep Power: 24 simonjrwinter has a spectacular aura about
427 cammer?
Somebody told me that this engine is a "427 cammer" wossat then?
GTD with Southern GT rear end. Lowered engine and gearbox. 302, R21T gearbox with LSD.
simonjrwinter is offline
Old 04-27-08, 04:06 PM   #2 (permalink)
jac mac's Avatar
jac mac
Rep Power: 18 jac mac has much to be proud ofjac mac has much to be proud of
Smile Re: 427 cammer?
FE with Single overhead cam per bank, row of rockers for both intake/exh valves-rockers have rollers on camshaft end. Virtual 'Hemi' chambers, both cams driven by one long chain from a short 'jackshaft' in the original cam position in block which in turn is driven by an original type chain setup.
Jac Mac,
DIY Mono MkIV,390,J44,15" Turbines.
jac mac is offline
Old 04-28-08, 12:46 AM   #3 (permalink)
Cliffbeer2
2 Tenths
GT40: CAV
Rep Power: 4 Cliffbeer2 is on a distinguished road
Re: 427 cammer?
I don't mean to take the thread off topic here - was just wondering if there has ever been a four cam version of either the SBF or big block (with the cam lobes driving the valves directly w/o rockers)?? And, if so, what kind of rpm would such an engine be cabable of?? Thanks in advance.
Cliffbeer2 is offline
Old 04-28-08, 08:47 AM   #4 (permalink)
sfm6s
Rep Power: 4 sfm6s is a glorious beacon of light
Re: 427 cammer?
What about the Ford Indy engine? Isn't it a SBF under all that exotic headgear?
sfm6s is offline
Old 04-28-08, 09:25 AM   #5 (permalink)
woodz428's Avatar
GT40: Il
Rep Power: 5 woodz428 is on a distinguished road
Re: 427 cammer?
Pretty close, it started as one when it was pushrod, but evolved drasticly. It is probably possible to adapt a set of heads to a small block, however there are more head studs and I'm not sure of the pattern.
Ford made some experimental heads back in the 60s for the SB, but never saw production. One had a similar set up as the Pontiac cammer 6,with tensioners and rockers, much like what was used on the 2.0 and 2.3 OHC 4s.
WDZ
woodz428 is offline
Old 04-29-08, 08:06 PM   #6 (permalink)
cushmancomp
Rep Power: 5 cushmancomp will become famous soon enough
Re: 427 cammer?
If you want to see the Ford 4-cam indy engines and parts go to my website and check them out at Home. I have about a dozen of them for sale. These cost $27,500 each in 1965 when a mustang convertible was about $3200 new. THey are not for the weak of heart.
cushmancomp is offline
Old 04-29-08, 08:09 PM   #7 (permalink)
cushmancomp
Re: 427 cammer?
Oh and I even have 1 of the Gt40 oil pans and bellhousing to put a 4-cam into a 40 with a ZF and a starter.
Old 05-02-08, 10:14 AM   #8 (permalink)
Conquest351's Avatar
Conquest351
3 Tenths
GT40: None Yet
Rep Power: 5 Conquest351 will become famous soon enough
Re: 427 cammer?
Must have more pictures of the Indy in the GT40!!!!!
Conquest351 is offline
