| Engine ID and Compression Test. Can anyone help with this?
Some time ago, I looked at the casting numbers on the engine, but did not come up with anything I could identify. Could not find anything above the starter motor. Lower down near the bottom of the block, I found 33 E7TE CA and what looks like an S on its side. Then there is a tag with 9D26 0
Cylinder Head 8F10 WCP 3
Now I don't think that there is anything special here, the fact that the engine had a Prestolite marine distributor may give a clue to that, but would just like to know if these tell me anything.
The other thing I was wondering about was compression ratio, now I guess that there is a relationship between compression test pressure and compression ratio. My compression test gave 9.0 to 9.5 Bar (130.5 to 137.8 psi). Just for a rough estimate without dismantling, some information I searched out suggested quite a low compression ratio. Anyone know what this relationship is, or can provide compression test pressure and compression ratio for their engine ?
thanks
__________________ DAX 302 Installing Alloy Rad |
