Old 12th May 2008, 12:51 PM   #1 (permalink)
simonjrwinter's Avatar
simonjrwinter
I Have No Life
302 engine mounts
Just tried to fit my 302 onto my Roy Smart engine mounts, but found that it didn't fit! The holes in the mounts when fitted to the engine are at least an inch or so too wide (each side) to fit into the mounts in the chassis. The distance between holes in the chassis mounted mounts (?) is 1ft 3 1/2 inches. Can anyone tell me if this is the standard distance on a GTD?
My local american spares shop tells me there are only one style of 302 mounts in the style I have?
Currently GT40-less
simonjrwinter is offline
Old 12th May 2008, 01:22 PM   #2 (permalink)
simonjrwinter
I Have No Life
Re: 302 engine mounts
OK, stop panicking.....going to re-drill the mounts that roy made
Currently GT40-less
Old 12th May 2008, 03:46 PM   #3 (permalink)
Brett James-McCall Moderator
brettmcc's Avatar
brettmcc
I Have No Life
GT40: RSGTD
Simon,
As I texted you earlier. You should not have to do this at all. Search the Forum and you will find I has this problem. I got my mounts from Roadcraft after having the same problem from Customville (I guess that is where you got them from).
It should be no more than having to get a drift to help them in.
Brett
Southern RSGTD; Mexican block; Audi 01X
I love the company so much I work for them and build them in my spare time....
brettmcc is offline
Old 12th May 2008, 08:29 PM   #4 (permalink)
Brian McCarthy's Avatar
Brian McCarthy
4 Tenths
GT40: GTD
If you use the rubber bushed engine mounts they will work with Roy's item, but if you upgrade to poly bushed mounts as I did, you may have to re-drill the mounts and dress them down a bit to provide clearance. I know it does not make sense, but that is what I had to do to get my motor down into the chassis.
Brian
...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...BRM Pin Drive wheels
...Gulf livery
Brian McCarthy is offline
Old 14th May 2008, 06:36 AM   #5 (permalink)
brettmcc's Avatar
brettmcc
I Have No Life
GT40: RSGTD
Exclamation Re: 302 engine mounts
Simon,
Before you drill/touch anything, go and read this thread here: Engine Mounts
It has all the information you need to fix, and I think you will find that the pictures are like yours.
Brett
brettmcc is offline
Old 14th May 2008, 11:23 AM   #6 (permalink)
PDub's Avatar
PDub
8 Tenths
GT40: Tornado
There are several different mounts for the 302 - I forget the exact year but there is one that has shorter "legs" where it bolts to the block, bringing the holes that bolt to the chassis closer together, i think you may need them.
Best regards,
P.
Black Tornado TS40 a.k.a. "Black Beauty"
SBF 306 / Edelbrock pack / R21-Turbo box / Quaife LSD
17" BRM Pindrives / Roll cage / Hi-Spec brakes
PDub is offline
Old 14th May 2008, 12:00 PM   #7 (permalink)
simonjrwinter
I Have No Life
Talking Re: 302 engine mounts
Not now I've become friends with the hacksaw!
Currently GT40-less
