Old 05-12-08, 07:58 PM   #1 (permalink)
Bill D's Avatar
Bill D
I Have No Life
CSR Adjustable Thermostat Housing Is A POS!!!!
I've tried for the past 40 minutes to get the &^^%&&%^$^%& o-ring to stay in the groove. I've tried gasket adhesive and nothing holds it. Any alternatives?
Bill D is offline
Old 05-12-08, 08:23 PM   #2 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 20 jac mac has much to be proud ofjac mac has much to be proud of
Smile Re: CSR Adjustable Thermostat Housing Is A POS!!!!
Grease-or petroleum jelly.
Jac Mac,
DIY Mono MkIV,390,J44,15" Turbines.
jac mac is online now
Old 05-12-08, 08:38 PM   #3 (permalink)
chuck 1's Avatar
chuck 1
7 Tenths
GT40: CAV
RTV is what I used on my FE expansion tank with an O ring, just a small bit in the groove
chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so
chuck 1 is offline
Old 05-12-08, 10:19 PM   #4 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 19 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
You really shouldn't have to put anything on that O-Ring to make it seal.
In my past experiences - any type of RTV or lubricant will just make it want to slip out of position.
If you really want to use a sealant on it - get some "Right Stuff" made by Permatex - sold at NAPA stores. clean all the parts perfectly and put a very thin smear of Right-Stuff on the manifold sealing surface, allow it to skin up for about 5 minutes and then put the housing in place.
Regards - Randy
Big-Foot is offline
Old 05-12-08, 11:43 PM   #5 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Sealing is not the problem. Keeping it in the groove is. It keeps popping out
Bill D is offline
Old 05-13-08, 12:46 AM   #6 (permalink)
no0one's Avatar
no0one
Rep Power: 2 no0one is a jewel in the rough
i've always used 4 evenly spaced dabs of RTV in the groove, and never had much of a problem. let the RTV sit ~5 minutes, untill it's really tacky...should do the trick. make sure to double check the o-ring is in the groove before you snug the bolts.
no0one is offline
Old 05-13-08, 03:06 AM   #7 (permalink)
Cliffbeer2
3 Tenths
GT40: CAV
Rep Power: 5 Cliffbeer2 is on a distinguished road
If the o-ring won't stay put with a dab or two of any of the above then you probably have an incorrectly sized o-ring. Many of the larger chain hardware stores (HomeDepot) have a selection of o-ring in different dimensions. Be sure to use an o-ring that sits slightly proud of the face surface. Nothing wrong with using any of the above as well for extra sealing - I prefer to use Permatex Form-A-Gasket rather than RTV for gasket sealing. I've seen excess RTV drool end up in some undesirable places (oil passageways).
Cliffbeer2 is offline
