Old 07-18-08, 06:46 PM   #1 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Rep Power: 21 wbmusarra is a name known to all
351 Windsor help
We are just about at the fire up stage with my build. Here is the problem.We are using the F.A.S.T. ignition system. After installing the crank balancer/spacer with the balance removed(engine is internally balanced), we ran into a problem with the front crank pulley setup. There will be a crank trigger installed and then the pulleys. We can't seem to find one that will mount or match up to the spacer. Spacer is a HiPo Ford piece. Was wondering what we are missing with our search. Everthing that we think will work, is either too small a diameter or the three bolt holes don't match up. Checked with the speed shops for Moroso etc., but without any success. Have had to return each piece that we have ordered. Do we need to look at the marine engines, or is there something that we are missing?? I want a double V belt arrangement to run the alternator and AC. We can't start the bracket fabrication til this is solved.The water pump has been removed for an electric setup, so the alignment is based on the crank pulley placement. The pics I am including are not the best in the world, but should give you an idea of what we are shooting for. Any help would be greatly appreciated.
Name:	Web P1010217.jpg
ID:	31218   Click image for larger version
Name:	Web P1010218.jpg
ID:	31219   Click image for larger version
Name:	Web P1010231.jpg
ID:	31220   Click image for larger version
Name:	Web P1010237.jpg
DRB#5
wbmusarra is offline
Old 07-18-08, 08:13 PM   #2 (permalink)
Rich_A
Rep Power: 7 Rich_A is on a distinguished road
Re: 351 Windsor help
Check with ASP Racing.
They have marine pulleys and probably make a custom pulley for you.
ASP RACING 1-877-928-8678
Rich_A is offline
Old 07-19-08, 01:43 PM   #3 (permalink)
David Briggs's Avatar
David Briggs
GT40: SPF MKI #2214
Rep Power: 9 David Briggs is a jewel in the rough
Cool Re: 351 Windsor help
Couldn't you redrill a 3 bolt pulley? MSD makes a non magnetic pick up, with brackets, that might fire that ignition.
Dave
SPF MKI #2214, 65 R model clone, 67 Al Craft Indy Car, 03 SL 500, 02 Lightning
David Briggs is offline
Old 07-19-08, 07:07 PM   #4 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 23 jac mac has much to be proud ofjac mac has much to be proud of
What Spacer- all I see in those pics is a Damper that appears to drilled/tapped to accept both 3 and 4 bolt crank pulleys that have a center location lip as part of the pulley- pretty standard stuff for all 60's 289/302/351w. Are you sure the pulleys the parts guys are trying to sell you are not for a SB Chev- the pcd of the chev 3 bolt pattern is about 1/16" smaller than the ford. Plus as Dave points out its no a big deal to redrill the ford 3 bolt to a 4 bolt pattern in most cases. Even the chev pulley could be used by slotting the holes slightly as long as there is enough material in the pulley to machine a register that suits your damper.
Jac Mac,
DIY Mono MkIV,390,J44,15" Turbines.
jac mac is online now
Old 07-20-08, 10:57 AM   #5 (permalink)
Jay P
Rep Power: 2 Jay P is on a distinguished road
There are three different thickness spacers available drilled for the Ford four bolt dampener/pulley, they are .380, .950 and .875. One of those should work for you. They should be available in any speed shop that sells Ford Motorsport parts.
Jay P is offline
Old 07-20-08, 05:29 PM   #6 (permalink)
wment
GT40: Valkyrie
Rep Power: 3 wment is on a distinguished road
A late 90s Explorer had a trigger wheel on the balancer. The one I am thinking of was a 302. Was there a 351 available? If so try looking for a balancer for one of them.
Wayne
wment is offline
Similar Threads
351 Windsor in an RF? mdemyanek Roaring Forties GT40s 3 08-16-05 07:21 PM
windsor or clevland 5112ja GT40 Tech - Engines/Induction/Exhaust 3 04-18-04 08:08 PM
48 IDA Manifold for 351 Windsor delaneyp GT40 Parts For Sale 0 01-15-04 10:06 PM
XE 351 windsor block tdm434m GT40 Tech - Engines/Induction/Exhaust 0 01-06-04 01:15 AM
351 Windsor Paul Bearman GT40 Cars For Sale 0 08-27-03 09:19 PM
