| Notices | Hi member,
Enjoy the forum!
09-30-08, 09:59 AM
#1 (permalink)
| | brettmcc 10 tenths
Rep Power: 20  | Intake Holes Apologies for the dumb question, but I have lost the manual and need some guidance. What are the three ports highlighted (feintly) for on the RPM Air-Gap manifold |
09-30-08, 10:00 AM
#2 (permalink)
| | brettmcc 10 tenths
Rep Power: 20  | Re: Intake Holes Hmm that didn't work well... I'll have to take a picture tonight.... |
09-30-08, 10:24 AM
#3 (permalink)
| | Womabt Silver Supporter
Rep Power: 3  | Re: Intake Holes Brett,
i believe top left is for the heater fitting, bottom left is temp sender and on the right is the vacuum port.
__________________ RCR 40, Ally block 302 B&S to 370 ci by T&L engines, ZF trans.
09-30-08, 10:26 AM
#4 (permalink)
| | Big-Foot Gold Supporter
Join Date: Jan 2007 Location: Minneapolis, MN GT40: RCR40 - #45
| Re: Intake Holes Quote:
Originally Posted by Womabt Brett,
i believe top left is for the heater fitting, bottom left is temp sender and on the right is the vacuum port. |
Correct! |
09-30-08, 10:35 AM
#5 (permalink)
| | brettmcc 10 tenths
Rep Power: 20  | Re: Intake Holes Simon, Randy, Anyone
What is the usual size of the heater fitting, as I thought it was that... but it is massive on my manifold i.e. my old 5/8 heater hose fitting is too small!
Brett |
09-30-08, 12:33 PM
#6 (permalink)
| Re: Intake Holes Brett I believe that they are drilled and taped for 1/2" NPT. You can get brass reducers at your local home improvement store in the hardware section. |
09-30-08, 01:57 PM
#7 (permalink)
| | Malcolm Gold Supporter
| Re: Intake Holes Brett, I have this manifold on my engine. If you want for a picture, ask away. One thing to note that it is a tall manifold compared to some I have had. With my holley on top I do not run an air filter (potential for problems I know) as the filter hits my rear screen. If you are running Roys lowered engine mounts you should not have this problem.
As to fittings I use top left for a air bleed off point. Bottom left is where my temp sender plugs in and I have blanked off the rear one (at least I think I have!) as my vacuum comes from the base of the carb.
Hope this helps.
__________________ Malcolm
GTD40, Mazda MAX5 MX5, Porsche 996 C4S
Lotus 51c for sale |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Mystery Holes? | ahirsbrunner | RCR Forum - RCR40 / RCR70 / P4 / MKIV | 2 | 09-22-06 01:52 PM | | NACA Duct Holes | Mark Clapp | GT40 Tech - Exterior, Interior, AC, & Trim | 0 | 07-02-04 01:21 PM | | Holes in panels | neils | GT40 Tech - Chassis,Brakes,Tires,&Wheels | 16 | 06-16-02 03:50 PM | | Front panel and holes... | Ron Earp | Roaring Forties GT40s | 3 | 03-22-02 10:18 PM | | Drillin' dem holes | Ron Earp | All GT40 | 6 | 10-18-01 12:44 PM |
