Old 4th January 2009, 05:24 AM   #1 (permalink)
jasonlycett
GT40: Worcestershire,
302 Fuel pump cam question
Just a quick question!
When fitting electric fuel pumps , does this allow you to get rid of the Fuel pump eccentric cam unit fitted onto the end of the timing gear?,
or does this perform some sort of balancing?
Thanks!
jasonlycett is offline
Old 4th January 2009, 07:27 AM   #2 (permalink)
saxoncross's Avatar
saxoncross
GT40: Tornado
Re: 302 Fuel pump cam question
Just fit a fuel pump blanking plate. If you are keen you could grind off the pump eccentric cam to improve the rotational inertia, but most people just leave them
Andy
saxoncross is online now
Old 4th January 2009, 08:54 AM   #3 (permalink)
Big-Foot's Avatar
Big-Foot
Super Moderator
GT40: RCR40 - #45
The 302 Ford used a bolt on fuel pump eccentric that you can just delete if so desired, or leave it in place. Either way, if your timing chain cover has a provision for the fuel pump, you will need to put a block off plate over the hole.
Regards - Randy
My build site:
Big-Foot is offline
Old 4th January 2009, 12:55 PM   #4 (permalink)
jasonlycett
Thanks Guys, i wanted to delete it because the cam dowel supplied with my Cam isnt long enough to retain the timing gear and eccentric, so thats good news!
Old 4th January 2009, 08:39 PM   #5 (permalink)
Rick
2 Tenths
The eccentric can be removed if desired. In its palce use a large thick hardened washer and a shorter dowel pin (in the cam)so that when the center bolt in the cam is tightened the dowel pin does not prevent (the washer) it from clamping flat against the face of the cam gear. Than as mentioned, cover the opening where the mechanical pump would normally mount.
It is easier and less expensive to change the pin in the cam to a longer one than do the above and purchase, and wire an electric pump.
Rick is offline
Similar Threads
Facet Red Top Fuel Pump ChrisMartino GT40 Tech - Fueling, Electrics, & Engine Cooling 3 26th September 2008 02:58 PM
fuel pump Frank Beuker The World Market - Share Parts, Sources, and Reviews 0 28th March 2008 07:28 PM
fuel pump question Dlampe GT40 Tech - Fueling, Electrics, & Engine Cooling 0 19th April 2007 08:06 PM
fuel pump sibbat2 GT40 Tech - Fueling, Electrics, & Engine Cooling 7 11th December 2006 02:46 PM
Fuel Pump Ron Earp GT40 Tech - Engines/Induction/Exhaust 4 18th September 2003 03:16 PM
