Originally Posted by saxoncross Thanks fro the feedback Chris. On your installation what is the length from the manifold to the top of the ram pipe
Andy |
Have now measured it and the figures are as follows:-
Manifold to inlet end of ram pipe - 175mm
From top of throttle body to inlet end of ram pipe - 90mm
The manifold is a Cobra one for Weber IDA/IDF and has a raised section for each carb choke/throttle body which is where the lower measurement was taken from. The bed of the manifold, ie the flat area between the 2 banks of cylinders, is about 85mm below the raised sections that connect to each throttle body. My throttle bodies are 48mm.
I hope all this is sufficient for your purpose. Measuring was a bit difficult because I have a turkey tray, which would require some dismantling to get a clear view of the manifold. All measurements should therefore be regarded as approximate.
Wishing you all the very best with your project.
Chris
