Hi, I am going to replace my coolant pipe's that run trough the backbone(in my europa) and want to use stainless steel instead of aluminium, the question is does stainless steel cooling lines promote dissimilar corrosion in the aluminium head? and how will the coolant fluid react on the stainless steel (reason for asking is that on the waterinjection kit I can't use an aluminium bottle because it will be eaten away by the water/meth mix)
thanks, rick
thanks, rick
