Old 23rd May 2012, 12:37 PM   #1 (permalink)
Jim
Chatas1
GT40: RCR
What size stacks for the webers?
Ok, I'm done with tires and moving on the the stacks! What size are you guys running? By size, I mean the height. I have seen the short ones (30's?) and the taller ones (50's?). I like the tall but I want to make sure they clear.
Thanks,
Jim
Chatas1 is offline
Old 23rd May 2012, 12:45 PM   #2 (permalink)
fastdruid
6 Tenths
GT40: GT-Forte
Re: What size stacks for the webers?
Where do you want to make your power?
Longer stacks make power low down, shorter ones make it higher up.
You can get an idea by playing with the calculator here
Velocity-of-Sound Intake Runner Length Calculator
Build log at http://fastdruid.co.uk/gt40/
fastdruid is offline
Old 23rd May 2012, 12:55 PM   #3 (permalink)
Ron Earp's Avatar
Administrator
GT40: None.
Check the automatic search results at the bottom of this thread.
Ron Earp is offline
Old 23rd May 2012, 02:53 PM   #4 (permalink)
fortyfied
I'm running the shorter stacks on my 347 and experiencing no problems at the top end or bottom.
fortyfied is offline
Old 23rd May 2012, 08:36 PM   #5 (permalink)
Jim
Chatas1
GT40: RCR
Thanks for the input. I hate to say it but I was concerned with the looks. I like the tall ones and I want to ensure they clear the glass. I assume they will? Ron, I read the other posts, thank you. I decided to go with a non EFI setup. Way too complicated for the amount of miles I will be driving it.
Chatas1 is offline
Old 23rd May 2012, 09:00 PM   #6 (permalink)
fastdruid
6 Tenths
GT40: GT-Forte
You wont experience 'problems' just that you'll make (relatively) more power at the top with short and more power at the bottom with long. I couldn't start to estimate how much but it's very real. This is why many manufacturers have played with variable length stacks to get the best of all worlds.
Some bikes even run different length stacks front to back or side to side to 'spread' the power. Looks a bit odd when you can see all of them though as in the GT40!
Old 24th May 2012, 12:30 AM   #7 (permalink)
Cliffbeer2
Gold Supporter
Jim, best to take a measurement off the top of your webers to the glass.....if your engine isn't mounted very low then you might find you don't have a lot of clearance, particularly if you're going to filter the intake air with traditional weber air filters.....
Cliffbeer2 is offline
Old 24th May 2012, 06:53 AM   #8 (permalink)
Jim C's Avatar
Jim C
Gold Supporter
GT40: RF 105
Longer the better I recon.
If you are tracking the car and never putting it on the road then work the shorter end of the scale.
If you are mainly road with the odd track day then look at the long.
The majority of your road driving will be in the mid range, if you loose a little top end at the odd track day it wont kill you.
Jim do a dummy up.plumbers pvc tube,heat the end with a hot air gun then push it onto the small end of a funnel,it will flare.
Make 8 short, 8 long and see what you like,you can also work your hieght as well.
My 2cents worth.
jim
If you say its to hard you have
already failed.
Jim C is offline
Old 24th May 2012, 07:11 AM   #9 (permalink)
Jim
Chatas1
GT40: RCR
This car may see a couple of vintage parades, I mean races... For the most part it will drive up and down Woodward Avenue and curvy roads that the big 3 use in the area. A friend of mine use to work on the corvette and he would take rides on certain routes in lower Michigan to test the cars. I would do the measurement but the car is at Fran's being prepped for shipping. I could wait until I get the car and test fit everything. I was just curious what you guys are running. As always, thanks for the input!
Chatas1 is offline
Similar Threads
8 stacks with two tanks LloydGT40 GT40 Tech - Fueling, Electrics, & Engine Cooling 63 6th December 2010 10:50 PM
Fuel injection stacks and manifold evomind GT40 Tech - Engines/Induction/Exhaust 12 20th September 2008 10:55 AM
IDA Stacks Rick GT40 Tech - Engines/Induction/Exhaust 1 28th September 2007 10:53 AM
Weber Venturi Size, Peak Power and Choke Size, 8 Barrel Venturi Size Ron Earp GT40 Tech - Engines/Induction/Exhaust 4 14th October 2006 01:08 AM
GT40 manifold and velocity stacks Bill Haralambakis The Garage Sale 8 20th March 2006 06:10 AM
