You should be able to use any ignition table for any DFI system, you will just have to enter the numbers into your table manually.
But, be warned, there is many factors in determining what your final ignition timing is going to be and anything anyone gives you runs a high risk of causing detonation. Chances are, the map you get from someone else wont be close to what you need as Steve has found out.
The worst thing you can expect when setting up a new DFI system is that your going to be up and running in no time at all. Patience is a huge virtue with these things.
Mick, having 8 throttle bodies doesn't mean a whole lot to the ignition table. How much compression, octane and cam sepecs are going to be much greater factors. Obviously, if I gave you an ignition table for a low compression engine, its probably going to blow up your engine.
I dont know the motec interface, but cold start is pretty easy to figure out yourself. I can give you some pointers if you like.
