Greetings from Ontario, Canada.
I'm installing an LS6 engine from an 02 Z06 in my project. I plan to use a custom wiring harness (Painless) and have been considering the use of the instrument cluster from a C6 instead of the C5.
Can you tell me if,
A) I will encounter any issues with any of the C6 gauges not functioning properly and if so, how to remedy?
B) will I need to make Painless aware of this to modify the harness to accommodate the C6 cluster if it will even work?
C) should I just stick with the C5 cluster?
Thanks for your input,
Can you tell me if,
