Coyote Intake Manifold Reversal?
Probably a long shot here, but is the Coyote intake manifold reversible? Can you flip it so the throttle body is pointing towards the flywheel?
Check out--Rentos GT-Forte GT40 Coyote Thread-than go to page 3.
There are pictures showing the procedure. Good luck ,I am doing the same thing.
i was looking at this a while back.
there are adaptor plates to go from mod to coyote upper
Manifold
so presume you could also get a plate made to go from coyote to mod, which would be handy as things like this are available for the mod
which would allow a standard air cleaner arrangement to be installed on the rear deck and go through the body work with out needing any modification.
Ryan
I did the same using a Cobra Jet intake. Just need to extend a wire and grind ever so slightly to remove a bit of material.
If it is him, what's going on in that bottom video!?
I will have a guessing they are checking/tuning for fuel reversion or stand of in the individual throttle bodies. adjusting the tune for very quick and clean throttle response. it certainly sounds very instantaneous and I can't see a cloud of fuel vapour coming back out the top of the trumpets.
Regards Ryan
