Engine Number Location on Coyote
I have stuffed my Coyote engine in my RCR40 and I cannot find the engine number. Does anyone have a coyote out of the car and could you tell me (possibly with a photo) where the engine number is located?
Thanks.
HERE!
Well my fingers are crossed anyway. It's always fatal when someone says
"hopefully this is the last time the engine will be out/apart."
I'm not so sure as that looks like a date and time. 01 07 10 10:54 XX:XX
There is a number on the side of the crank case under the engine near the pan. it is XXX/XX/XXX in format. Any one have any ideas whether the "date" one is correct on top?
The pic I posted is a new bare block, presumably it had not been stamped with a vin type number, here is another XR8 block with what appears to be a FPV # from a cobra builders site, you might also check out post #'s 215 & 229 of your build thread as your pic has another partially obscured number in the centre of the valley also.
