Spark plugs..
Hi guys and gals ... When fitting spark plugs to alloy heads does any body use a grease of any kind ..?? I have new heads on my 302 and didn't want to naff them up ..
Thanks in advance .. John..
Doug S.
I use anti-seize compound. Most spark plugs are made of a metal that interacts negatively with aluminum...this can cause spark plugs to seize in the threads. The anti-seize compound keeps this from happening.
Cheers!
Doug
Do not under any circumstance use Copper coat or any thing with copper in it.
A Nickel based antiseize would be my preference followed by a graphite based one.
A number of spark plug mfgrs are recommending to NOT use anti-sieze on their plugs.
There are a few reasons which make sense -
@ plug threads are nickle clad or other aluminum friendly plating
@ too easy to overtorque as torque values are given with dry threads
@ not all anti-seize compounds are conductive
@ potential for fouling the plug by over application
@ potential for contamination of the insuator thereby causing a short from the lead to ground
All that said, I personally would not think of installing a plug in an aluminum head without having a small dab of anti-seize on the threads. Just go easy and remember that your torque values should be reduced by 10-15 percent (this is a number I feel relatively safe with - your mileage may vary)...
Doug S.
thanks guys ... where will I get anti seize please ....
jc....
Any automotive parts shop...I long ago bought a large bottle because it is good for more than just spark plugs.
The source from which I bought the urethane bushings for the suspension bars on my Cobra replica specified anti-seize compound for lubricating the bushings...I have had not a single squeak from them since I used the anti-seize.
You will find many more uses around the house for anti-seize, too.
Cheers!!
Doug
