Assuming that you have a standard GTD with thr Renault gearbox, simply set the no 1 piston at TDC on the firing stroke ( find TDC by removing all spark plugs and using an appropriate probe in No 1 bore through the spark plug hole ) then mark on the flywheel edge through the bell housing opening( at the top of the housing right hand side from the clutch slave. ) where you will find timing marks in the casting. Mark with white paint on the flywheel edge to correspond with the 0 mark on the bell housing. Use a timing light with an advance dial ( I use a SnapOn ) set a static advance to about 18 degrees to start the engine, the take the engine to maximum point of maximum mechanical advance ( somewhere about 3500 rpm ) and set the timing mark on the flywheel to corresponde with the 0 mark on the casting with the timing light set to 34 - 36 degrees to suit whatever cam you are using. These are basic guidelines, you need to determine your own settings, but on most 302 Fords in the GTD40 this will get you pretty well there. NOTE - do not use vacuum advance on the dizzy!
