Rotating intake 180 degrees
I have seen a lot of LS engines on this site with the intake rotated 180 degrees with the throttle bodies and air filter toward the rear. Is this something that is fairly easy accomplished? Anyone care to describe what the process is and if there is a brand of efi intake that makes this process less complicated? Thanks for your feedback.
Charlie
The intake is symmetrical. Unbolt it and turn it around. DO NOT switch the coils around.
20 minute job! You'll have to bend the air bleed tube slightly.
