Go Back   GT40s.com > >
Thread Tools Display Modes
Old 20th June 2017, 01:50 PM   #1
wolodymyr's Avatar
wolodymyr
GT40: DAX40
Cam Synch or distributor stub for EFI
Are there any uk sources for Dorman 689-103 cam synch or other EFI distributor stub for 302 SBF?
Dave
1991 DAX 302 full Performer rpm package installed
wolodymyr is offline   Reply With Quote
Old 20th June 2017, 04:07 PM   #2
Joules5's Avatar
Joules5
GT40: ERA MK1 Gulf
Re: Cam Synch or distributor stub for EFI
$48.97 + 8.265% tax from Summit Racing and I'm just down the road from the Sparks NV store. Shoot me a PM and I'll pick one up and mail to you if you cannot get it local in the UK. You can pay me via equivalent GBP deposit into Lloyds account or Paypal.
Julian
ERA Gulf GT40 #2041
Pantera's '81 GT5 & '74 L
Swift 008 Formula Atlantic
Ultima CanAm
Joules5 is offline   Reply With Quote
Old 21st June 2017, 03:18 AM   #3
saxoncross's Avatar
saxoncross
8 Tenths
GT40: Tornado
Hi Dave,
Are looking for a cam sync sensor, because your ECU needs the input signal or it a convenient way of removing the distributor whilst still retaining the oil pump drive from the camshaft?
On the system Iíve used it relies on the crank & TPS signal only for mapping. I then converted my old distributor to the following photo
Is this something I could do for your installation?
Rgds,
Andy
Cam Synch or distributor stub for EFI-oil-pump-drive-jpg
Failure is not an option, but cock-ups will happen
saxoncross is offline   Reply With Quote
Old 21st June 2017, 07:45 AM   #4
wolodymyr's Avatar
wolodymyr
GT40: DAX40
Hi Andy, thanks, it was just a convenient way of maintaining oil pump drive. I would have converted my original distributor except that it is in poor condition. I have a relatively new Mallory Unilite, but I would be reluctant to chop it.
A second hand distributor is an option.
For your system, I guess that you just need a distributor shaft? It looks like you have put ball bearings in a machined boss so my old distributor shaft might do it, with a new gear as the old one is trashed.
Hi Julian, thanks for your kind offer, I will let you know if I want to do that.
Dave
Old 21st June 2017, 08:00 AM   #5
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
Make sure whatever you choose that the distributor gear is compatible with your camshaft.
Putting an iron distributor gear on a steel cam will be a recipe for disaster. Similarly a steel distributor gear against an iron cam.
Regards - Randy
-- Youth and talent are no match for old age and treachery!
GT40 RCR40 #45 G50-331-Weber IDAs ((Sold))
My build site:
Old 21st June 2017, 08:04 AM   #6
wolodymyr's Avatar
wolodymyr
GT40: DAX40
Randy, thanks, mine is an Edelbrock 2222 camshaft which is steel. I made sure the distributor gear was also. This is worth repeating a million times if it saves one person from a bad experience
Dave
Old 21st June 2017, 09:06 AM   #7
saxoncross's Avatar
saxoncross
8 Tenths
GT40: Tornado
Hi Dave,
your're correct in your assumptions and only the shaft and a suitable drive gear is required for this conversion.
Rgds,
Andy
Old 4th July 2017, 07:58 AM   #8
wolodymyr's Avatar
wolodymyr
GT40: DAX40
I ended by ordering a cam synch from Summit, together with a fuel solenoid switching valve for my tank return. I will post pictures in my main thread.
Tags
cam, distributor, efi, stub, synch
Forum Jump
