Hi All,
I am having an engine built by Chris Smith at Devon Racing and was hoping that someone may have experience with an engine to a similar specification. Does the specification look like a good combination of components and how much BHP and torque might the engine make?
Induction system is an IDA manifold pattern 8 stack EFI system running a FAST ECU.
It is a 331 stroker built into a 302 block.
Engine spec.
331*
Steel 3.0 x 3.25 in crank
Pro street crank damper.
Forged rods
Keith black hyperutectic pistons
10 : 1 cr
All above race balanced.*
Modified pro sport cyl head 1.9 in 1.6 exh
Com cams 268xe camshaft
Comp cams roller rockers
Melling hp oil pump
Svo oil pump drive
Cloyes performance roller timing ser
Arp head studs
Arp engine bolt kit
Modified mallory distributor*
Velpro gaskets
Airtex r/h water pump
March pulley set
65 type alternator brket
Moroso front sump
Many thanks all!
Tom
Engine spec.
331*
Forged rods
10 : 1 cr
Melling hp oil pump
Svo oil pump drive
Arp head studs
Arp engine bolt kit
Velpro gaskets
March pulley set
Moroso front sump
Many thanks all!
Tom
