Old 04-11-07, 06:24 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
porsche93's Avatar
porsche93
2 Tenths
GT40: RF Chassie 90
Rep Power: 8 porsche93 is on a distinguished road
Help on throttle cable hookup.
As you can see in the attached picture, the end of my throttle cable has a 90 dagree ferrell on it. I need to connect this to the throttle on the manifold as shown in the second picture. The problem is that I cannot find anything that connects to the ferrell and would allow me to conect to the throttle arm.
I checked with Lokar and was told about a universal part that I could use but it would require cutting the ferrell off of the cable and inserting the cable end into this part were it would be held with a set screw. My concern is the set screw slipping and the cable being pulled out at a bad time.
Any suggestions?
Peter
ID:	19038   Click image for larger version
Roaring Forties #80
306CUI, SBF,8 Stack Injection
Motec M800 ECU
Audi 5N with 3.22 Ring and pinion
17 inch Vintage Wheels
Florida Plate # GT40 MK1
porsche93 is offline
Old 04-11-07, 06:52 PM   #2 (permalink)
YerDugliness
GT40: Yellow Wix MKII
Rep Power: 9 YerDugliness will become famous soon enough
Re: Help on throttle cable hookup.
How about soldering an appropriate fitting that would be more secure to the cable (after removing the offending ferrell) and then attaching it to the Lokar piece? If I recall correctly, throttle cables are fairly easy to attach to with solder (did it once on a motorcycle throttle cable and had no problems with it for a long time).
Just a thought.
I hesitate to mention it, but perhaps sourcing a different throttle cable and fishing it through the tunnel might be a better idea. Sure sounds like a lot of work, though.
Doug
YD,E./PNB
Retired and attempting to age disgracefully
YerDugliness is offline
Old 04-11-07, 07:18 PM   #3 (permalink)
Bill Pinzini's Avatar
Bill Pinzini
GT40: RCR work in progress
Rep Power: 3 Bill Pinzini is a jewel in the rough
Lokar makes a cable end w/ 2 set screws I used one my Cobra never had a problem, but soldering would be a better way to go.
Bill Pinzini is offline
Old 04-12-07, 12:54 AM   #4 (permalink)
2124's Avatar
2124
6 Tenths
GT40: Rescue, CA
Rep Power: 11 2124 is a glorious beacon of light
Make sure you silver solder it, Bill -should work fine.
CAV #80, 331 Keith Craft, RBT Swift DB5
2124 is online now
Old 04-12-07, 02:33 AM   #5 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Peter, you seem to be missing the throttle cable pulley under the bell-crank (see attached pics of a standard RF / DC&O setup). I'm not sure how the end of the cable is secured to the pulley wheel - perhaps just a section filed out of the rim to accept your 90deg ferrule ?
My feeling is that a pulley is better than having the cable just pull on one of the bell-crank ears as you get a linear relationship between the pedal & the butterfly positions. With the direct pull on a bell-crank ear, you will probably get an over-sensitive throttle near idle, & can expect some wear on the cable as it changes direction out of the cable-sheath according to throttle position.
Another advantage of the pulley setup is that you could use a "reducing radius" pulley to give you a low "gear ratio" near idle, but a smooth transition to a faster pull near WOT. You would still get a bit of cable wear, but I am looking into changing mine like this as I have limited pedal travel.
Hope this helps a bit.
Kind Regards,
Peter D.
ID:	19043   Click image for larger version
DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl
delaneyp is offline
Old 04-12-07, 06:05 AM   #6 (permalink)
Fatal Attraction's Avatar
Fatal Attraction
GT40: Ex-DRB #35
Rep Power: 23 Fatal Attraction has a spectacular aura about
Peter,
Peter D is correct on all points. You will need the pulley, or the pedal effort
will be massive. Your cable cable end should lock into a notch in edge of the
pulley. With the pulley in place, you will be able to get get 270º or more of
smooth pull, pretty much guaranteeing you full range of cable motion from
idle to WOT. Once you have tensioned the cable (at idle) from the pedal end,
The cable end (at the pulley) will stay put in the notch.
My TWM setup also had a bracket in that held the cable sheath in place.
This would be a good idea, if you don't have one already, to keep the pulling
point static, and to avoid the off chance of the cable jumping out of the
pulley groove.
Ex-Gt40 Australia #35
351W 425HP
TWM 8 stack TBI
MOTEC M4
G50/Quaife LSD
Fatal Attraction is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-tech-engines-induction-exhaust/21442-help-throttle-cable-hookup.html
Posted By For Type Date
GT40s.com This thread Refback 04-11-07 07:11 PM
