Old 12-11-06, 12:36 AM   #1 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Pop Out Window Hinge Orientation
Which way do the hinges go?
Version 1 - hinges parallel to the top and bottom
Version 2 - hinges perpendicular to the sides
Bill D
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 12-11-06, 12:52 AM   #2 (permalink)
Mark Clapp's Avatar
Mark Clapp
4 Tenths
GT40: Mark I (South Africa)
Rep Power: 12 Mark Clapp is a jewel in the rough
Re: Pop Out Window Hinge Orientation
I've always noticed them as parallel to the sides as in your example 1.
Kit Car Centre Mk I (South Africa)
Mark Clapp is offline
Old 12-11-06, 02:00 AM   #3 (permalink)
CliffBeer's Avatar
CliffBeer
CURRENTLY BANNED
GT40: CAV mono
Rep Power: 0 CliffBeer can only hope to improve
Well, theoretically, to get them to swing open properly without binding, the axis of rotation for each hinge has to be in line (translation: in-line and perpendicular to the front side). There may be enough slop in the hinges to allow you to mount them without the axis of rotation (meaning, the line drawn through the hinge pins) exactly in line if it's displeasing to the eye.
This is completely unrelated to the axis of evil in which case you can do anything you want apparently.
CliffBeer is offline
Old 12-11-06, 05:28 AM   #4 (permalink)
Brian Magee's Avatar
Brian Magee
GT40: GTD
Rep Power: 12 Brian Magee is on a distinguished road
Mine are fitted as the second example so that the two pivot pins face each other. The sliding fastener on the back edge of the window should be the other way round so that the locking button is on the fixed part of the window, not the hinged part.
Brian.
GTD, 289, ZF.
Brian Magee is offline
Old 12-11-06, 07:58 AM   #5 (permalink)
Dalton
4 Tenths
Rep Power: 8 Dalton is just really nice
For goodness sake don't get them lined up with the axis of evil, or we Ozzies will be over there helping George W bomb the cr*p out of your GT40.
Having the two hinge axes in one straight line, as has been recommended, is kinematically correct.
Dalton
Dalton is offline
Old 12-11-06, 10:57 AM   #6 (permalink)
salmjo1's Avatar
salmjo1
3 Tenths
Rep Power: 7 salmjo1 will become famous soon enough
+1. You want the hinges to rotate on exactly the same axis. You can position the slider at whatever height to make it look right.
salmjo1 is offline
Old 12-13-06, 02:11 PM   #7 (permalink)
Mark Charlton's Avatar
Mark Charlton
Canada
GT40: GTD #9988
Rep Power: 10 Mark Charlton is a splendid one to behold
Here's an original. Looks like the axis of evil...
Name:	window hinges.jpg
Mark Charlton
____________
GTD40 #09988
71 DeTomaso Pantera
70 DeTomaso Mangusta
Mark Charlton is offline
Old 12-13-06, 02:16 PM   #8 (permalink)
Mark Charlton
Canada
GT40: GTD #9988
And another (both are original cars).
Mark Charlton
____________
GTD40 #09988
71 DeTomaso Pantera
Old 12-13-06, 04:58 PM   #9 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Wink Re: Pop Out Window Hinge Orientation
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 12-13-06, 05:38 PM   #10 (permalink)
Mark Charlton
Canada
GT40: GTD #9988
At the risk of being flamed by Ron for thread-drift ( ), doesn't it seem like you should at least get a 30-day warranty when you spend $3,000,000 on a car? (see previous photo)
Mark Charlton
____________
GTD40 #09988
71 DeTomaso Pantera
Similar Threads
Rear Window, any opinions?? Julian West GT40 Tech - Exterior, Interior, AC, & Trim 17 05-06-08 01:36 PM
Bulkhead window gasket/surround Brian McCarthy GT40 Tech - Exterior, Interior, AC, & Trim 4 11-26-06 11:01 PM
GT front window FredGT40 GT40 Wanted - Parts or Services Needed 9 09-07-06 08:26 AM
Authentic side window hardware available AluminumGT40 GT40 Parts For Sale 3 03-11-05 07:09 PM
Authentic GT40 side window hardware available AluminumGT40 All GT40 4 03-08-05 02:56 PM
