Brake Snorkel Scoops Question..
TonyM
Is there are correct way to install the scoops? I have seen where they are integrated or blended into the rear section and I have seen where they are surface mounted with rivets. Is one way correct or is it a matter of choice? Also, does anyone have any dimensions to go off of in regard to the mounting position?
Thanks,
TonyM
Tony, email me your mailing address to [email protected]. I can make you a paper template to locate the snorkle scoops and mail it to you. It will locate the holes in the rear deck in relation to the rear window. Most scoops that I have seen are pop rveted on.
TonyM
Thanks, I have emailed you.
TonyM
