Chris Duncan
Sort of new to this HVLP spray gun. Works fine when first used but after a re-load it spatters. Seems like the paint dries a little in the nozzle piece because it takes a while before it clears up and sprays right.
What is the normal procedure? Do you flush the thing with reducer right before a reload?
Is it correct when the paint calls for 10 psi air pressure that that is the dynamic pressure and not the static pressure? In other words for it to be at 10psi while the trigger is pulled it has to be at 18psi when the trigger is off.
