| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Tech - Exterior, Interior, AC, & Trim All that other stuff not in categories above. |
03-22-07, 08:13 AM
#2 (permalink)
| | Big-Foot Gold Supporter
Join Date: Jan 2007 Location: Minneapolis, MN GT40: RCR40 - #45
| Re: Removeable side windows popping back to the top in the hopes that someone has some input to this subject.. Thank you.. |
03-22-07, 10:45 AM
#3 (permalink)
| | llarsen Admin
Rep Power: 29   | Re: Removeable side windows Randy,
DRB (GT40 Australia) has (had?) an ally framing system to do this:
03-22-07, 12:05 PM
#4 (permalink)
| Re: Removeable side windows HI Lynn,
Thanks for the info - It's certainly a step in the direction I was contemplating. Not sure of the "wing-window" look.. I'll certainly be considering it though.. |
03-22-07, 12:29 PM
#5 (permalink)
| | llarsen Admin
Many people have used nut-serts, well nuts or heli-coils to receive the window screws so that removal/replacement can be done fairly quickly.
Helicopter vents or Snap air vents like these from Aircraft Spruce have also been used (click image to see Aircraft Spruce's catalog listing):
Lynn
03-22-07, 01:06 PM
#6 (permalink)
| | Gary Kadrmas Silver Supporter
Join Date: Sep 2006 Location: Oregon, USA GT40: Not yet, but so
| Re: Removeable side windows I recall the MkIIIs had hinged side windows. It would seem this would help a great deal for ventilation.
I do not know if the MkIII windows are available and/or if the hinges would allow you to remove them when the need arose.
Can anyone out there expand on this,.......and post any pictures maybe?
Thanks,
__________________ Gary Kadrmas
___________________
Owner of CSX-2075 for over 30 years, and wanting a GT40 for over 20 years |
03-22-07, 02:00 PM
#7 (permalink)
| | MikeDD 10 tenths
Rep Power: 21  | Re: Removeable side windows Gary
I believe DRB's window arrangement is essentially same as the MK III.
Despite what the above photo shows, I'm pretty sure the whole deal is an assembly that inserts into the existing MK 1 door.
That said...its NOT cheap. A sliding plexi window (see original MK IV photos)
would be cheap/easy/effective....although it is crude looking.
MikeD
__________________ DRB GT40 # 49 (for sale)
RCR Lola MK IIIb |
03-22-07, 02:01 PM
#8 (permalink)
Rep Power: 17   | Re: Removeable side windows Gary,
Here is a shot of a MkIII window
__________________ Cordially, James MKI monocoque. XE' 289 short blocks, C6FE heads, Webers, ZF Graviner Fire Suppression |
03-23-07, 03:07 PM
#9 (permalink)
| Re: Removeable side windows Jimmy Mac,
Thanks for posting the MkIII side window. I have never seen a real MkIII in person, and from the looks of it, a possibility exists the set-up could be made to be able to remove the larger square portion of the window? I do
not know for sure. Maybe someone that has more first hand knowledge could chime in on this one. Anyone out there that works in a race car shop that has been close enough to expand on this?
Thanks again for posting the picture. Me being an old fart, I tried several times to post the thing, and failed.  When I have my son over to the house for dinner the next time, I am sure he can guide me in the right direction.
One last thing.....do you know of the chassis number of the car in the picture?
Thanks,
___________________
03-23-07, 03:20 PM
#10 (permalink)
Rep Power: 17   | Re: Removeable side windows Hi Gary,
The machine in question is GT40 P1103 now in the Motor Museum at Beaulieu, Hampshire, in the south of England.
There are a few shots of it on this forum however here are a few more.
03-23-07, 03:45 PM
#11 (permalink)
| Re: Removeable side windows James,
Thank you for the excellant pictures. Thats what I like about this forum. People helping people.
___________________
03-25-07, 06:30 AM
#12 (permalink)
| | delaneyp Peter D
Join Date: Sep 2001 Location: Sydney, Australia GT40: DRB #27
Rep Power: 21  | Re: Removeable side windows I have the DRB MKIII windows - aly frames & perspex like the one Lynn shows below. However, I did not bond the surrounding outer f/glass frames into the door, but kept them separate so that I could swap between this setup & the full perspex windows in the future.
The whole outer f/glass frame is just bolted into the door with s/s bolts & helicoils in the f/glass.
I have found the openable main windows a blessing - heaps of fresh air if you want it, you can pay tolls on expressways (although this is a dying art with electronic tags these days !), you can take the whole lot out very easily & have a large open window (with surprisingly little wind turbulence in the cabin), etc.
The only downside of this setup is that when you have the windows open, you look a bit like a fighter jet which has just deployed its air-brakes !!
The following early pic shows the car with the main windows removed, but you can see the separate outer frame & its securing bolts.
Kind Regards,
Peter D.
__________________ DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl |
03-25-07, 07:18 AM
#13 (permalink)
| | 7 Tenths
Join Date: Oct 2003 Location: Magazine Editor (finance magazine) and Freelance Writer (classic car articles) GT40: Robin Hood Country, England
Rep Power: 13  | Re: Removeable side windows The KVA MKIII had opening side windows similar to the original MKIII, without the chrome surrounds. It's simliar to the DRB set-up (nice car Peter) but they had squared off rear bottom corners and they weren't removable.
How about electric side windows (see below)?
Good luck - Rob
__________________ Rob
1968 BRE Datsun 2000 Roadster replica
1972 BMW 3.0 CSL Batmobile
1963 Lola MK6 GT replica project (VERY slow progress ...)
(No GT40 at the moment) |
03-25-07, 12:18 PM
#14 (permalink)
| Re: Removeable side windows GREAT PICS GUYS!
One of the main drivers behind my quest for better ventilation is that I live in a climate that really only has a few weeks of higher temps (upper 90'sf) in the summer. If I could arrange the cabin ventilation better and with proper insulation from the engine-bay, I may be able to get by without adding AC. Fran's got a great AC Kit so it won't be any intrustion (other than to my wallet) to implement - but I like to make things simple as possible in addition to enjoying the moderate climate during summertime.
Lynn - The Helicopter vents would be another good option for getting a little more airflow in the cabin.
JimmyMac - That P1103 is certainly a different looking animal.. I like it!
Peter D
I will probably end up with windows such as yours.. Peter, I love your car. I'm really hooked on the dark blues. Currently planning on Ford's Sonic Blue for mine. I also love the side mirrors you have. PM coming..
Rob - Thanks for the shot of the KVA MKIII with rollup windows Also - From the look of it, they cleared the door handle linkage by splitting the side-glass leaving the rear-most section stationary. While I'm not a big fan of electric door poppers (although I've never had them) - I think that would be one way of engineering around the moving glass channel.
On another note for those that have driven their 40's sans side glass -
What are the characteristics of the airflow in the cabin? Is it fairly decent inside or are you hammered by buffeting to the point where you slow down from normal highway cruising speeds? |
03-25-07, 04:04 PM
#15 (permalink)
| | wbmusarra 10 tenths
Join Date: Oct 2001 Location: Snellville, Ga. GT40: DRB#5
Rep Power: 20  | Re: Removeable side windows There are several types of vents that have been employed by both originals and replicas. Here is one I posted of the 66 Road Car.
__________________ DRB#5
351W/408 DIS TWM F. I. 930 Porsche LSD |
03-26-07, 05:15 PM
#16 (permalink)
| | wealdenengineer 10 tenths
Rep Power: 0  | Re: Removeable side windows Our solution, remove window and screw on these small deflectors useing the same screw holes, good to 150mph and no wind buffeting. Frank
Reason: pics added....
03-26-07, 07:21 PM
#17 (permalink)
| | xlr8or Rookie
Join Date: Apr 2006 Location: San Diego CA GT40: None yet, that's next on the list.
Rep Power: 3  | Re: Removeable side windows Nice solution Frank. Looks like something that would work well here in Southern California. |
