Old 04-15-07, 04:47 PM   #1 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
GTD Harness Bar
I've managed to lose the mails where some kind forum members had given me the specs of thier harness bars in their GTDs. I would appreciate it people could let me know what size tubing they have used. Much appreciated. Thanks
Brett
Roy Smart GTD Chassis with complete Southern GT Rear modification
Chris Melia Body
Mexican block
Audi 01X that just needs the gear change sorting
brettmcc is offline
Old 04-16-07, 07:23 AM   #2 (permalink)
Brian McCarthy's Avatar
Brian McCarthy
GT40: GTD
Rep Power: 12 Brian McCarthy is a glorious beacon of light
Re: GTD Harness Bar
Hi Brett, I guess you could use a tube or flat bar. I don't have any pics handy, but I used a 1/2" by 1" flat bar welded on to a small piece of 1/4" plate to pick up the mounting bolts. For what it was worth, I used the same flat plate to pick up the engine bay strut bolts coming into the cockpit.
You are likely aware of this, but the harness bar bolts must run through the piece of angle iron in the engine bay and it's important to use washers or similar to spread the load on the eye bolts.
If you have the patience, I'll send some pics this coming weekend.
Brian
...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...BRM Pin Drive wheels
...Gulf livery
Brian McCarthy is offline
Old 04-16-07, 08:54 AM   #3 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: GTD Harness Bar
Thanks Brian. Didn't know about the angle iron piece, so am looking forwrad to the pics.
Brett
brettmcc is offline
Old 04-19-07, 12:42 PM   #4 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: GTD Harness Bar
Any other suggestions from any people running GTDs?
Brett
brettmcc is offline
Old 04-19-07, 07:57 PM   #5 (permalink)
David Morton's Avatar
David Morton
GT40: The Jewel on th
Rep Power: 37 David Morton has a brilliant futureDavid Morton has a brilliant futureDavid Morton has a brilliant future
Re: GTD Harness Bar
Hi Brett. I hope to go over and see my car this weekend and I'll take some pics then. It's a bar arrangement again.
David Morton is offline
Old 04-23-07, 07:27 AM   #6 (permalink)
jimp's Avatar
jimp
GT40: RML40
Rep Power: 6 jimp is on a distinguished road
Re: GTD Harness Bar
Hi Brett,
The harness bar assembly of my GTD40 comprises a steel bar 910x30x6mm fitted immediately below the level of the bulkhead window trim and into which are fitted the harness eyebolts at 250mm centres. This is bolted through (2 @ 8mm and 2 @ 10mm dia) a 25x25x4mm steel angle section located in the engine bay.
The upper "horizontal" leg is notched in the centre to clear the distributor cap.
The eyebolts appear to be 8-10mm thread dia (sorry, needs stripping to find out) and do NOT pass through the angle.
Hope this is of assistance.
Good luck with the build.
Jim
RML 40
jimp is offline
