| Re: fuel filler cap and mount flange Hi Huw, I have some pics showing the install of fuel filler caps. I installed the filler neck under the spider. Drill and fit nutsert into the filler neck (no nuts can fall of) cork gasket then spider, another cork gasket then filler cap. Spider is sandwiched between the cap and the filler neck.
This makes it an easy task to remove the spider if necessary without involving the removal of the fillerneck from the tank.
Mick
__________________ 40 INCHES |
