Old 07-28-07, 01:41 AM   #1 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Door Trim
I was wondering if anyone has some bright ideas on how to securely fix interior door trim panels to the doors ?
I would like to make the panels easliy removeable - a local upholsterer suggested those horrid little plastic "christmas tree" fittings that you see on new cars, but I reckon that a few removals would see the holes in the f/glass become pretty ragged.
Given that I don't want screws visible from the inside, I figure the best way would be to mount studs into the trim's backing plate prior to covering - these would just slide into holes in the doors & have nyloc nuts & washers fitted inside the doors. (I am going to keep the main access holes in the doors open (carpet inside to doors) so that I can access the storage space without opening the doors - as is necessary with those hinged fold-down type of door trims).
So, the big question is how to secure coutersunk head bolts into the backing plates without using nuts ?
My thoughts so far have run to :
- Backing plate made from MDF, c/s bolts held in place by a thin sheet of f/glass in each side.
- Backing plate made from aly sheet, c/s bolts brazed in place across the heads (don't know if you can braze across s/s & aly).
Any other ideas would be greatly appreciated.
Thanks & Kind Regards,
Peter D.
DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl
delaneyp is offline
Old 07-28-07, 05:46 AM   #2 (permalink)
trojan007
GT40: Own build
Rep Power: 6 trojan007 is a jewel in the rough
Re: Door Trim
If you use good quality plastic clips it shouldn't be a problem, also make sure you use male and female clips so you don't get the ragged look later on. Also use the correct trim removal tool and a half decent tool operater and the clips should last at least up until your funeral
Steve
trojan007 is offline
Old 07-28-07, 08:02 AM   #3 (permalink)
PDub's Avatar
PDub
6 Tenths
GT40: Tornado
Re: Door Trim
Did mine with 5mm plywood frames, then put in rivnuts into the wood and just pop a m4 allen head bolt in from the inside of the door pocket out. Once you know it fits ok you can cover the outside with foam/trim and they are easily removable. I also put a piece of angled ally along the bottom edge so that there isn't too much flex when you pull on it - negating the need for a door handle.
Best regards,
P.
Black Tornado TS40 a.k.a. "Black Beauty"
SBF 306 / Edelbrock pack / R21-Turbo box / Quaife LSD
17" BRM Pindrives / Roll cage / Hi-Spec brakes
PDub is offline
Old 08-01-07, 08:24 AM   #4 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Re: Door Trim
Thanks Steve - cheeky young lad ! FYI, I am planning on outlasting a few miserable plastic clips !!
Paul, that sounds like a good approach. Did you put the riv-nuts in from the door-side of the ply ? Also, my only experience with riv-nuts has been with the ones that lock into fairly thin sheet metal - did you use these & just rely on the nut body squeezing out into the ply & locking it in ?
Thanks guys,
Kind Regards,
Peter D.
331 Windsor / GD-50
delaneyp is offline
Old 08-01-07, 10:22 AM   #5 (permalink)
trojan007
GT40: Own build
Re: Door Trim
Mr D,
You can get rivnuts that will go into softer material, I have all the tools for rivnuts if you need it. A good place to get them from is Aerobolt at Chipping Norton, if you are using the standard nuts I have them.
Steve
