| Re: Original heater matrix and box Forgot to mention its from a Land Rover Series II. The original box sucked air through the fan and out the sides of the box. The 'flip' sides on the box were used to provide crude airflow, basically left, right or both!!!.
The GT40 conversion will suck air through the side via filtered grills (to be made) and blow hot air out the fan hole into a custom made plenum.
The plenum will have 2 ducts to the windscreen grill and a butterfly valve allowing feet warming.
__________________ replica mono chassis
original rear clip
1966 289
48IDA's
This month its going to be red
'This car you have to be measured for...'
