| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Tech - Exterior, Interior, AC, & Trim All that other stuff not in categories above. |
12-09-07, 05:19 PM
#1 (permalink)
| | Bill D I Have No Life
Rep Power: 34   | Shoulder Harness Pass Through My shoulder harnesses will pass through the rear bulkhead and attach to the roll bar in the engine compartment. What are people using to frame the hole and prevent damage to the harness?
Bill D
__________________ Bill D
RCR GT40 Mk1 Gulf |
12-09-07, 08:51 PM
#2 (permalink)
| | VintageVenom 6 Tenths
Join Date: Oct 2005 Location: Michigan, USA GT40: RCR-40
Rep Power: 12   | Re: Shoulder Harness Pass Through Bill,
Finish line Cobra used to have dress rings for this purpose. Not sure if they still do, but thought I'd throw it out there.... |
12-09-07, 10:02 PM
#3 (permalink)
| | jonathans Silver Supporter
Rep Power: 7  | Re: Shoulder Harness Pass Through I used grommets cut into a C shape in each corner and U shaped trim along each length. Not very pretty but on the inside I covered it all with the carpeting. |
12-09-07, 10:10 PM
#4 (permalink)
| | Pantera1889 10 tenths
Join Date: Jul 2003 Location: Maryland,USA GT40: RCR MK1
Rep Power: 19   | Re: Shoulder Harness Pass Through Bill,
I used the dress rings that Rob mentioned.They worked out great! I'll try to post a picture tomorrow.
How is the build going??
I don't see the " final assembly" tab on your site any longer.
__________________ RCR GT40 MK1 chassis #14
DeTomaso Pantera #1889 |
12-09-07, 11:36 PM
#5 (permalink)
Rep Power: 34   | Re: Shoulder Harness Pass Through Thanks guys. I bought some machined aluminum trim rings used by the Factory Five Cobra guys. I plan to have them powdercoated black.
Ron
I deleted it because it became too difficult to maintain. I need to focus on the build and not taking/posting pictures. I have one more item to fabricate (a cable shifter cover) and then I can disassemble the chassis for the powdercoater.
RCR GT40 Mk1 Gulf |
12-10-07, 08:54 AM
#6 (permalink)
| | FRPGUY Bronze Supporter
Rep Power: 6  | Re: Shoulder Harness Pass Through Bill, you know you have a fire in the engine compartment when the shoulder belts become loose! Make sure the fit is tight around the belts where they come through the firwall, I had fire tickling the back of my neck as I blasted down the straight at Lime Rock Race track with an engine fire. I wouldn't have belts come through the firewall again thanks! I would find a way to mount them on the inside of the cabin.
__________________ may no resin cure before it's time |
12-17-07, 05:21 PM
#7 (permalink)
Rep Power: 34   | Re: Shoulder Harness Pass Through Can I mount them to eye bolts mounted through the bulkhead and through the roll bar?
RCR GT40 Mk1 Gulf |
12-17-07, 10:06 PM
#8 (permalink)
| | gt40fran Sponsoring Vendor
Join Date: Sep 2001 Location: Manufacturer of GT40: Michigan,USA
| Re: Shoulder Harness Pass Through If you have a certified welder attach a threaded boss/nut plate to the bolt cage...I do not see why not.
This would save you having to cut slots in your firewall and be a much neater and simpler solution....also less chance of fumes coming through....IMHO.
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF www.RACECARREPLICAS.COM www.superlitecars.com
12-17-07, 10:42 PM
#9 (permalink)
Rep Power: 34   | Re: Shoulder Harness Pass Through Thanks Fran. I'll pursue this solution.
Bill D
RCR GT40 Mk1 Gulf |
